Tubeless roadbike tyres
Re: Tubeless roadbike tyres
Postby Mr Purple » Wed Oct 18, 2023 11:43 am
I suspect the answer is a better bike fit, and potentially a slightly longer stem and frameset. The last KOM I took on those road tyres was 450W for 1:13, and half of that was down a steep hill. The bike was literally jumping off the road on the 15% climb that started it.
I'm 172cm and suspect my initial road bike bought in 2009 or so was slightly too short for me. And since then because I was comfortable on that the two subsequent frames have been based on those measurements. The reason I can't sit to climb is because it's uncomfortable to do so - I suspect I'll need to stretch out a bit more and correct for my leg length discrepancy.
This does not happen at all on my gravel bike. Despite that taking more KOMs than my road bike currently - it's a bit longer, you have to stay seated to climb on most gravel segments and it rewards finesse more than brute strength.
Why is it every question in cycling is answered with 'n+1'?
Postby blizzard » Wed Oct 18, 2023 12:27 pm
Maybe a bike fit and even some coaching sessions on climbing out of the saddle technique? If I climb out of the saddle I just do whatever feels ok, but I do know there is proper technique to help distribute weight better and climb more efficiently. I guess like anything it's a skill that can be learned. You might even get more KOMs as a result.Mr Purple wrote: ↑Wed Oct 18, 2023 11:43 amYou may well be right.
Postby Mr Purple » Wed Oct 18, 2023 12:39 pm
I have done a few rides with a mate who's a physio - he's pretty convinced it's a leg length discrepancy with a compensating scoliosis and as a result I have to stand to correct it. Though his theory was it was effective enough that I don't have to worry about it just yet - rear tyre wear excepted.blizzard wrote: ↑Wed Oct 18, 2023 12:27 pmMaybe a bike fit and even some coaching sessions on climbing out of the saddle technique? If I climb out of the saddle I just do whatever feels ok, but I do know there is proper technique to help distribute weight better and climb more efficiently. I guess like anything it's a skill that can be learned. You might even get more KOMs as a result.
There's no doubt standing on some climbs is significantly slower for a given power, but I suspect the given power is a lot higher than it would be seated. Sooner or later I won't be able to rely on VO2Max and will have to sort the technique out a lot better.
I'm vaguely considering a new bike at some stage so will get a bike fit with a decent physio before doing it. Might need some shims or something as well.
- MichaelB
Postby MichaelB » Wed Oct 18, 2023 2:20 pm
That, or set up a company as a tyre reseller and get trade pricing based on the usage of you alone !
Postby Mr Purple » Wed Oct 18, 2023 2:29 pm
Well it's not that bad.
I probably only do about 100km in an average week on the road bike now - the rest indoors on gravel. So one rear tyre lasts 800km, that's 8 weeks and 6.5 a year - at $75 apiece that's $487 or 9.3c/km. By comparison my BMW gets 9L/100km, so about 20c/km.
Actually, that is pretty bad!
- MichaelB
Postby MichaelB » Wed Oct 18, 2023 4:44 pm
You'll soon have to go for shorter and shorter road KOM's as they cost you too muchMr Purple wrote: ↑Wed Oct 18, 2023 2:29 pmWell it's not that bad.
Postby Mr Purple » Wed Oct 18, 2023 7:55 pm
The shorter ones are worse! Pretty sure the 300m long 14% one I took at 690W a couple of months back killed one tyre on its own. You could hear the 'ching, ching' of tyre manufacturer cash registers as it happened.MichaelB wrote: ↑Wed Oct 18, 2023 4:44 pmYou'll soon have to go for shorter and shorter road KOM's as they cost you too muchMr Purple wrote: ↑Wed Oct 18, 2023 2:29 pmWell it's not that bad.
The fact the segment was called 'Argh!' was probably a warning sign.
Postby vosadrian » Wed Nov 15, 2023 7:51 am
Postby Mr Purple » Wed Nov 15, 2023 3:40 pm
I'll let you know - given I'm a consumer of tyres I'm always on the lookout.
Best deal currently I've seen is $49 for Goodyear Eagle F1 tubeless at CCache. A pair just arrived today for me.
https://ccache.cc/collections/road-tyre ... tyre-black
Postby warthog1 » Wed Nov 15, 2023 3:55 pm
https://ccache.cc/collections/road-tyre ... -ascending
Postby vosadrian » Wed Nov 15, 2023 4:01 pm
Postby Mr Purple » Wed Nov 15, 2023 4:37 pm
Not yet - there's about 3W rolling resistance between them and the Contis, but the Vittoria NEXT TLR I currently use are about the same and they've been fine.
https://www.bicyclerollingresistance.co ... ext-tlr-28
Interestingly I hadn't really noticed a huge speed difference between tubed and tubeless since I changed over in April. But did a couple of Gravatts last week - a climb I've been avoiding since April because I always find the need to VO2Max it and it hurts.
It's a bumpy, twisty descent and despite taking it what I thought of as relatively easy I set two PBs on it last week. I think just a result of lower pressures leading to greater confidence there in particular.
Postby vosadrian » Wed Nov 15, 2023 5:13 pm
I think I will wait until black friday and see if any deals come up on Contis, but if not I might grab a few of the Goodyears to give them a go.
Postby Mr Purple » Wed Nov 15, 2023 6:27 pm
'Price' is the main consideration. Rolling resistance probably makes little difference, but I don't like being discouraged by weather so wet grip is also a big factor. Other than that punctures haven't been an issue on tubeless (yet).
I'd sort of like to try the very fastest road tyres at least once (Vittoria Corsa Speed TLR at 7.0W) to see what they're like, but suspect I'll kill them before I really get the chance to find out.
Postby vosadrian » Wed Nov 15, 2023 7:47 pm
Postby warthog1 » Wed Nov 15, 2023 8:38 pm
Since used Pirelli, Michelin and Vittoria. Honestly noticed no difference in speed.
Dont even look at Conti anymore due to price.
Postby vosadrian » Fri Nov 24, 2023 11:25 am
- foo on patrol
Postby foo on patrol » Fri Nov 24, 2023 4:41 pm
I saw some yesterday or the day before but can't remember who had then.
Foo
Goal 6000km
- grt046
Postby grt046 » Sun Nov 26, 2023 10:34 am
On checking it over and dusting it down I noticed a small bubble of sealant still sticky on both wheels .... one spot on each. No significant loss of pressure so fingers crossed it is doing its job.
Will keep a check on it for a while.
I was a bit surprised this occurred after a period of no use.
Postby warthog1 » Sun Nov 26, 2023 10:54 am
What tyres and what sealant?grt046 wrote: ↑Sun Nov 26, 2023 10:34 amI haven't ridden the road bike this month due to some prostrate issues (surgery next Saturday) so I put it on the stand and spun the wheels for a while to distribute the sealant.
Good luck with the surgery, hope it improves things.
- grt046
Postby grt046 » Sun Nov 26, 2023 11:44 am
Tyres are Pirelli
P Zero Race (30) front
Cinturato Velo (32) rear
Tyres were installed by the local TREK shop so Bontrager TLR sealant used.
Postby warthog1 » Sun Nov 26, 2023 1:56 pm
Haven't used that sealant but it seems to be doing its' job and some must still be liquid after sitting unused.
I don't know if you have had a go yourself yet. If you search youtube "tubeless tire install" some useful vids are there.
Postby blizzard » Sun Nov 26, 2023 6:23 pm
What a pain to get off the rim and then cleaning dried sealant off the rim and tyre. Surprisingly easy to get the tyre back on, I got it so there was only about 10cm or so to go, and it was pretty tight. Then I remembered the trick of standing on the tyre with the last section on the ground and then using the rim as lever to pull it on... Worked a charm. Seated first time with an air shot.
As an aside, I think I have about 9000km on these tyres and there is still life in them. I put it down to heaps of flat Bikeway KMs on smooth concrete (and poor power output).
- grt046
Postby grt046 » Sat Dec 09, 2023 12:13 pm
Well after putting a toe in the water with a tubeless conversion on my Orbea Gain with an initial shaky start I am now at a stage where I need to take the next step and set myself up to manage things myself rather that use the local TREK shop over the road (300 metres away)warthog1 wrote: ↑Sun Nov 26, 2023 1:56 pmHaven't used that sealant but it seems to be doing its' job and some must still be liquid after sitting unused.
I have watched a number of videos and researched sealant tests which come up with conflicting results so am looking some real world feedback on what works best in our climate.
As my cheapie track pump is some 14 years old I am considering replacing it with something like a Topeak Joe Blow Booster HP Road Floor Pump or alternatively an Airshot tyre inflator rather than a compressor as living in a smallish villa with single garage where space is at a premium.
I am currently using Pirelli tyres set up with Bontrager TLR sealant as installed by the TREK shop. (Details above)
As for sealant I am a bit confused as it would appear that Stans Original and Orange Seal Endurance seem popular locally although they didn't perform too well in some artificial testing (Screwdriver puncturing in differing sizes)
The Silca sealant seemed best at sealing large holes with its c/f content I have ruled that out as it can't be injected through the valve stem.
Any real world experiences/recommendations would be appreciated.
- grt046
Postby grt046 » Sat Dec 09, 2023 12:14 pm
