Shimano part Y0C698050. c.$14 depending on shipping prices locally, IF in stock. Given ten minutes I can make one now that I know the thread sizes required and have the stock and tooling to do so. But that's turned into a 'next weekend' job now.g-boaf wrote: ↑Mon Apr 22, 2024 2:46 pmDoes Shimano make and sell the adaptor? Preferably not available from overseas, only through local distributors?
I didn't do anything with my bike today - feeling off today so worked off site. It needs a clean from the Sunday ride but can wait.
I probably need to change the tyres, the ones on it are starting to look flat across the top.
What did you do with your bike(s) today?
- familyguy
Re: What did you do with your bike(s) today?
Postby familyguy » Mon Apr 22, 2024 2:58 pm
- biker jk
Postby biker jk » Mon Apr 22, 2024 4:50 pm
I purchased mine for $2.99 from BikeBug as part of a larger order so received free shipping.familyguy wrote: ↑Mon Apr 22, 2024 2:58 pmShimano part Y0C698050. c.$14 depending on shipping prices locally, IF in stock. Given ten minutes I can make one now that I know the thread sizes required and have the stock and tooling to do so. But that's turned into a 'next weekend' job now.g-boaf wrote: ↑Mon Apr 22, 2024 2:46 pmDoes Shimano make and sell the adaptor? Preferably not available from overseas, only through local distributors?
- find_bruce
- Moderator
Postby find_bruce » Mon Apr 22, 2024 5:50 pm
Glad your ok. Tell the insurer it's irreplaceable
Postby robbo mcs » Mon Apr 22, 2024 7:31 pm
There is actually a fair bit of fake shimano stuff around. I got stung with some spd cleats. They were in short supply for a while, I found some on ebay, bought 2 sets, didn't think much about it. They wore out after around 1000kms, which is weird as normally they last forever. Looked at the other set I still had, and the packaging was dodgy. There is supposed to be a section where you peel back to reveal qcode, which verifies the product. This package the peel back bit was just printed, and didn't even peel back.find_bruce wrote: ↑Mon Apr 22, 2024 9:47 amOne possibility is that they're knock-offs - even cheaper if they don't have to copy the packaging. It's not just Rolex etc these days & it's a real problem in the aircraft industry
Checking online, apparrently a real problem with shimano stuff, chains, pads, cleats etc.
Postby Andy01 » Tue Apr 23, 2024 8:13 am
You might be right. I had no idea that there may be counterfeit bike chains out there ?find_bruce wrote: ↑Mon Apr 22, 2024 9:47 amOne possibility is that they're knock-offs - even cheaper if they don't have to copy the packaging. It's not just Rolex etc these days & it's a real problem in the aircraft industry
Postby stevenaaus » Tue Apr 23, 2024 8:07 pm
Holy hell... I bought myself a decent straight BB wrench so i can hit the tough ones with a hammer, but have never had one that bad.foo on patrol wrote: ↑Mon Apr 22, 2024 1:50 pmFinally got the BB cups off = two blokes, a 600mm breaker bar, and a vice on a 250Kg metal bench.
Foo
- foo on patrol
Postby foo on patrol » Tue Apr 23, 2024 9:56 pm
stevenaaus wrote: ↑Tue Apr 23, 2024 8:07 pmHoly hell... I bought myself a decent straight BB wrench so i can hit the tough ones with a hammer, but have never had one that bad.foo on patrol wrote: ↑Mon Apr 22, 2024 1:50 pmFinally got the BB cups off = two blokes, a 600mm breaker bar, and a vice on a 250Kg metal bench.
Foo
Yeah, it's not what I expected niether I can tell you. I also put a clamp on the tool to stop it from riding the notches because without that, it justed wanted to keep rising up.
Foo
Goal 6000km
- P!N20
Postby P!N20 » Wed Apr 24, 2024 10:37 am
Good news: fork is repairable
Bad news: three month wait
Good news: driver has paid for repairs without any arguments
- familyguy
Postby familyguy » Thu Apr 25, 2024 7:07 pm
- elantra
Postby elantra » Thu Apr 25, 2024 10:32 pm
Kudos !
Even if the big-brand part is not exy ($$$) sometimes it’s quicker and easier to fudge it yourself.
Sometimes not, but as they say, nothing ventured nothing gained.
I was talking to a bloke the other day. He said that for certain wheel bearing extraction you can buy an expensive bearing puller …. Or you can get the same result with a cheap Dyna-bolt from the local hardware store
- familyguy
Postby familyguy » Fri Apr 26, 2024 9:13 am
Postby warthog1 » Fri Apr 26, 2024 2:24 pm
4 baths of turps to get rid of the black sh it
Then 3 of metho.
Took the sunrace 32-11 cassette of the kickr core and swapped it with the 34-11 of the WR50s I am running with road tyres o the Revolt.
Drip wax is far cleaner than purple extreme like I used to use, but hot melt wax bathed chains are heaps cleaner again.
Postby warthog1 » Fri Apr 26, 2024 9:23 pm
I have just bought a couple of "ultegra" 11 s chains off ebay. Pretty sure they are going to be counterfeit too.find_bruce wrote: ↑Mon Apr 22, 2024 9:47 amOne possibility is that they're knock-offs - even cheaper if they don't have to copy the packaging. It's not just Rolex etc these days & it's a real problem in the aircraft industry
I read some feedback after purchase and they were counterfeit.
Pretty common apparently
https://matthewbrealey.medium.com/fake- ... 2ef76c8aa2
Never returned anything from ebay. Probably won't be easy
- g-boaf
Postby g-boaf » Sat Apr 27, 2024 8:55 am
If you do you homework and give them the correct info should be okay.warthog1 wrote: ↑Fri Apr 26, 2024 9:23 pmI have just bought a couple of "ultegra" 11 s chains off ebay. Pretty sure they are going to be counterfeit too.find_bruce wrote: ↑Mon Apr 22, 2024 9:47 amOne possibility is that they're knock-offs - even cheaper if they don't have to copy the packaging. It's not just Rolex etc these days & it's a real problem in the aircraft industry
I took my bike outside and brought it straight back inside. It was cold this morning and I didn’t have any motivation to ride outside.
45 minutes of Zwift workout (a high intensity one) was enough.
- familyguy
Postby familyguy » Sat Apr 27, 2024 6:10 pm
Pulled the quill stem out of the Gazelle, cleaned it, put it back in. Creak resolved.
- foo on patrol
Postby foo on patrol » Wed May 01, 2024 5:44 am
Foo
Goal 6000km
- foo on patrol
Postby foo on patrol » Thu May 02, 2024 12:59 pm
Foo
Goal 6000km
Postby warthog1 » Thu May 02, 2024 2:55 pm
Have you tried wheels manufacturing?foo on patrol wrote: ↑Thu May 02, 2024 12:59 pmTried to find a new hanger online. I may have to get one that's close but has the same bolt hole spacing and then do some back yard butchering so that it fits the dropout. If I new how to use my 3D printer properly I could possibly make a new one if I could create the file.
Foo
A few came up when I put "wheeler" into the bike brand search.
https://wheelsmfg.com/catalogsearch/result/?q=wheeler
- foo on patrol
Postby foo on patrol » Thu May 02, 2024 7:08 pm
warthog1 wrote: ↑Thu May 02, 2024 2:55 pmHave you tried wheels manufacturing?foo on patrol wrote: ↑Thu May 02, 2024 12:59 pmTried to find a new hanger online. I may have to get one that's close but has the same bolt hole spacing and then do some back yard butchering so that it fits the dropout. If I new how to use my 3D printer properly I could possibly make a new one if I could create the file.
Foo
No, I'll have a gander ta.
Foo
Goal 6000km
- foo on patrol
Postby foo on patrol » Thu May 02, 2024 7:20 pm
Foo
Jebus, I just had a look and they have one but would end up costing me nearly $80.
Foo
Goal 6000km
Postby warthog1 » Thu May 02, 2024 8:06 pm
Must be the postage and exchange rate?foo on patrol wrote: ↑Thu May 02, 2024 7:20 pmwarthog1 wrote: ↑Thu May 02, 2024 2:55 pmHave you tried wheels manufacturing?foo on patrol wrote: ↑Thu May 02, 2024 12:59 pmTried to find a new hanger online. I may have to get one that's close but has the same bolt hole spacing and then do some back yard butchering so that it fits the dropout. If I new how to use my 3D printer properly I could possibly make a new one if I could create the file.
Foo
Foo
I would do that rather than bodge something up.
Tubeless tyres cost that much but I pay it, as they just work.
- foo on patrol
Postby foo on patrol » Fri May 03, 2024 4:22 am
warthog1 wrote: ↑Thu May 02, 2024 8:06 pmMust be the postage and exchange rate?foo on patrol wrote: ↑Thu May 02, 2024 7:20 pmwarthog1 wrote: ↑Thu May 02, 2024 2:55 pm
Foo
I'd put the old one back on before I'd pay that much for $3 worth of aluminium.
Foo
Goal 6000km
- WyvernRH
Postby WyvernRH » Fri May 03, 2024 10:16 am
Not something I've done for a modern bike, but looking at the sacrificial hangers on a couple of my modern bikes and those photos I would say you could make a replacement out of aluminium or steel plate fairly easily?foo on patrol wrote: ↑Fri May 03, 2024 4:22 amwarthog1 wrote: ↑Thu May 02, 2024 8:06 pmMust be the postage and exchange rate?foo on patrol wrote: ↑Thu May 02, 2024 7:20 pm
Foo
Foo
I've made a few of the old 'claw' type hangers (normal and reverse) to cope with the differing requirements of older derailleurs over the years and it wasn't too hard.
Postby warthog1 » Fri May 03, 2024 10:50 am
And have your rear derailleur end up in the spokes or similar?foo on patrol wrote: ↑Fri May 03, 2024 4:22 amwarthog1 wrote: ↑Thu May 02, 2024 8:06 pmMust be the postage and exchange rate?foo on patrol wrote: ↑Thu May 02, 2024 7:20 pm
Foo
Foo
No thanks.
There are significant costs above the price of the aluminium to make so many different hangers. They are listed at $27- which is a damn sight cheaper than a wrecked derailleur and or wheel. Yes I have had that happen.
- elantra
Postby elantra » Fri May 03, 2024 3:58 pm
Yeah surely it’s tempting to try and “make” a new one.WyvernRH wrote: ↑Fri May 03, 2024 10:16 amNot something I've done for a modern bike, but looking at the sacrificial hangers on a couple of my modern bikes and those photos I would say you could make a replacement out of aluminium or steel plate fairly easily?foo on patrol wrote:
Foo
In a perfect world you would be able to make one with a 3D printer.
But I guess that there is no “blueprints” for the derailleur hangers of most models of bicycle.
And if made out of plastic the derailleur hanger would probably bend and twist just a bit too much for optimal function - especially on a hot day !
A bit like in the old days - the 1970’s Simplex derailleurs and derailleur change levers (made out of plastic) seemed to have a bit too much independent movement
