Parramatta river cycle way
- g-boaf
Re: Parramatta river cycle way
Postby g-boaf » Sat Aug 05, 2023 11:25 am
- recumbenteer
Postby recumbenteer » Mon Aug 07, 2023 4:52 pm
unless you're in the jellybean.... for me it's the parting of the seas...
Rotovelo Across Australia
- g-boaf
Postby g-boaf » Mon Aug 07, 2023 7:16 pm
You can just barge them out of the way.recumbenteer wrote: ↑Mon Aug 07, 2023 4:52 pmunless you're in the jellybean.... for me it's the parting of the seas...
- Retrobyte
Postby Retrobyte » Wed Aug 23, 2023 1:17 pm
The detour has been in place since Monday this week - the detour takes you along the narrower path that runs up past the dog park, tennis courts, and back down past the cricket field. It's the same distance as the path that is closed, so not inconvenient at all - just a few blind corners to be careful around because of the temporary fencing.Retrobyte wrote: ↑Thu Aug 03, 2023 3:47 pmThe dual path runs from the boardwalk in the east to the path intersection at the western end, just above the downward blind curve - between the white dots in this image. The path is the first job they're doing as part of the upgrade - and will be closed/diverted from Monday 14 August until April (estimated)Retrobyte wrote: ↑Wed Aug 02, 2023 8:08 amThe upgrade to George Kendall Park starts this week - this includes improving the drainage to prevent the path from being flooded in wet weather, and also a new path to separate pedestrians from cyclists for the length of the current path that runs from the boardwalk on the eastern end to the wide path in front of the apartments at the western end. Not sure if this includes the blind S bend curve at the western end.
Lighting for the path is in the draft concept plan, but that may have changed so I have made some enquiries about that and am hoping to get a copy of the final plan.
Postby LateStarter » Tue Oct 03, 2023 1:03 pm
and...LateStarter wrote: ↑Wed Aug 02, 2023 11:11 amParramatta Council site now says Alfred St bridge "delayed" (again) and will open in "September" (I assume they mean 2023?)Retrobyte wrote: ↑Sun Apr 16, 2023 11:51 amThe span for the new Alfred St pedestrian/cyclist bridge was put in place this week - will be open in a few weeks. This new bridge is located just west of James Ruse Drive, and will provide a shortcut to the CBD instead of crossing at one of the other bridges or causeways on the Parra Park end of the ferry wharf
Still a bit of work to connect Alfred St end to other paths but will be nice
September Update, next update will mention "early 2024" perhaps,
"There have been further delays to the completion of the Alfred Street Bridge beyond Council's control (contractor and steel supply), and it is now anticipated to open late October or early November of this year."
2008 Cannondale Touring 2, 2013 Vivente World Randonneur, 2015 Lynskey Sportive Disc
- Retrobyte
Postby Retrobyte » Fri Oct 13, 2023 10:08 am
Of course, the latter didn't stop a jogger from running along the bike path on my commute home one day this week.
They told me they can't paint centre lines or keep left arrows along the path across the river from the new Powerhouse Museum site because of the artwork painted on the path - it would impact the aesthetics
The Alfred St bridge is inching closer and closer to completion - the balustrades are all in place now, and signage is painted on the approaches.
- Retrobyte
Postby Retrobyte » Tue Oct 31, 2023 8:28 am
- Retrobyte
- mikesbytes
Postby mikesbytes » Wed Nov 01, 2023 8:33 pm
Nice. Could do with a centre line however no one was walking/riding/whatever in the wrong way... this time
What does it do to your commute? IE what improvement? It's been a long time since I've ridden around there
- Retrobyte
Postby Retrobyte » Wed Nov 01, 2023 8:42 pm
I think the centre line will come in due course - they've made a few improvements recently along the river cycleway, with centre lines on bends, and keep left arrows in some locations.mikesbytes wrote: ↑Wed Nov 01, 2023 8:33 pmNice. Could do with a centre line however no one was walking/riding/whatever in the wrong way... this time
In terms of my commute, it removes a 1km section of path next to the river where it is mobbed with people who are not bike-aware, kids who run across the path without looking, people taking selfies etc. I trade that off with a slightly longer on road section through the Parra CBD, but the new route is definitely safer.
Postby JPB » Sun Nov 12, 2023 7:34 pm
I went through the diversion today. With the high temporary fences and twists and turns I was worried that I had entered The Labyrinth and I might encounter the Minotaur.Retrobyte wrote: ↑Wed Aug 23, 2023 1:17 pmThe detour has been in place since Monday this week - the detour takes you along the narrower path that runs up past the dog park, tennis courts, and back down past the cricket field. It's the same distance as the path that is closed, so not inconvenient at all - just a few blind corners to be careful around because of the temporary fencing.Retrobyte wrote: ↑Thu Aug 03, 2023 3:47 pmThe dual path runs from the boardwalk in the east to the path intersection at the western end, just above the downward blind curve - between the white dots in this image. The path is the first job they're doing as part of the upgrade - and will be closed/diverted from Monday 14 August until April (estimated)Retrobyte wrote: ↑Wed Aug 02, 2023 8:08 amThe upgrade to George Kendall Park starts this week - this includes improving the drainage to prevent the path from being flooded in wet weather, and also a new path to separate pedestrians from cyclists for the length of the current path that runs from the boardwalk on the eastern end to the wide path in front of the apartments at the western end. Not sure if this includes the blind S bend curve at the western end.
- Retrobyte
Postby Retrobyte » Mon Nov 20, 2023 8:52 am
The diversion has been removed some time since Thursday last week - the new section of separated path along the river is now open .....
Postby DojoBuff » Sun Dec 03, 2023 8:14 am
- Retrobyte
Postby Retrobyte » Sun Dec 03, 2023 10:44 am
Yes, seems the remedial drainage work is still underway, given how much water and mud was on the path after the rain last week. I noticed that boundary rope was on the path on Thursday evening, so disappointing it is still there 3 days later.DojoBuff wrote: ↑Sun Dec 03, 2023 8:14 amQuite a bit of mud on the new section this morning, so ride slowly to avoid slippage and mud splatter. There's also a boundary rope that was strewn across the path and my bike got tangled up in the dark. Next time I'll take the northern cycleway if there has been recent rain.
Postby tez001 » Sun Dec 03, 2023 12:15 pm
Postby Cycling Wombat » Sun Jan 21, 2024 9:35 am
- Retrobyte
Postby Retrobyte » Sun Jan 21, 2024 3:01 pm
I've been told the drainage improvements won't be completed until the work above the path is finishedCycling Wombat wrote: ↑Sun Jan 21, 2024 9:35 amSo they didn't do a very good job on the path at George Kendall reserve. Still floods and gets covered by standing water and mud.
Postby robbo mcs » Sun Jan 21, 2024 7:37 pm
Postby Cycling Wombat » Mon Jan 22, 2024 9:59 am
On another note, I did do a search but couldn't see anything already posted, is it easy enough to ride from Parramatta Park and connect up to the M7 pathway via mostly separate cycleways and shared paths?
- g-boaf
Postby g-boaf » Mon Jan 22, 2024 12:35 pm
Yes, entirely off road.Cycling Wombat wrote: ↑Mon Jan 22, 2024 9:59 amHopefully there's further improvements to come then.
Take Westmead exit from Parramatta Park then get yourself onto the Old Windsor Rd shared path. It’s been this way for many many years.
If you use Strava routes feature it should show you because that should be the most popular way (by the heat maps).
Postby AndrewCowley » Mon Jan 22, 2024 2:22 pm
Postby caneye » Mon Jan 22, 2024 6:06 pm
It's only a short stretch that has driveways - i.e. Toongabbie (between Fitzwilliams and Reynolds) - and even then, it is a relatively quiet street.AndrewCowley wrote: ↑Mon Jan 22, 2024 2:22 pmEek that Windsor Rd path looks like a death trap though. So many driveways.
Majority of it is on a separate cycle path.
Postby robbo mcs » Mon Jan 22, 2024 8:04 pm
Old Windsor rd, not Windsor rd.AndrewCowley wrote: ↑Mon Jan 22, 2024 2:22 pmEek that Windsor Rd path looks like a death trap though. So many driveways.
As stated, there are a couple of short sections on quiet roads. The rest is separated, either next to the t-way or alongside the road, but no driveways. There are a quite a few annoying intersections at traffic lights however.
Postby AndrewCowley » Mon Jan 22, 2024 9:00 pm
- Retrobyte
Postby Retrobyte » Mon Jan 22, 2024 9:13 pm
They had carpet down today on the section of the new path where most of the mud has been pooling. It's a stretch of maybe 15m. Better surface than the dried up mud, that's for sureRetrobyte wrote: ↑Sun Jan 21, 2024 3:01 pmI've been told the drainage improvements won't be completed until the work above the path is finishedCycling Wombat wrote: ↑Sun Jan 21, 2024 9:35 amSo they didn't do a very good job on the path at George Kendall reserve. Still floods and gets covered by standing water and mud.
