pedalling technique and leg muscles
Postby the dang » Mon May 18, 2009 11:55 am
I have been commuting to work a few times a week for a few months now. I noticed that the main muscle which is sore/tight after riding is in my thighs (quads) but there is hardly any noticable ache or tightness in the hamstrings. Is this normal for cycling or is my pedalling technique possibly not correct causing the quads to work most (I am assuming my quads are working harder hence the more noticable ache).
If it is normal for the quads to work hardest, then should I do other hamstring exercises to balance out the muscles? Because I have noticed some development in the quads but no change really in the hammies since cycling.
Also, are there any tips or links to resources on what is and how to develop good pedalling technique.
The Dang
Re: pedalling technique and leg muscles
Postby brendancg » Mon May 18, 2009 12:38 pm
- JV911
Postby JV911 » Mon May 18, 2009 2:10 pm
is your seat high enough? </opens another can of worms>
check out some of the online calculators for a rough guide. if the consensus is that it is too low, maybe start by increasing your seat height by no more than 5mm at a time
- toolonglegs
Postby toolonglegs » Mon May 18, 2009 2:36 pm
Postby the dang » Mon May 18, 2009 8:10 pm
Thanks for the replies...regarding seat height, I set it using the heel on the pedal technique so that when the ball of my foot is on the pedal at the bottom of the stroke, my knee is slightly bent.
I guess the main question I was trying to ask is..."is the main muscle recruited, the quads?" - if the answer is yes, then that is probably why my quads burn the most when cycling, and if the answer is no, then maybe something is not right with me or my bike causing my ache specifically in my quads and less elsewhere.
and then also, if it is normal for quads to work hardest, should I balance out the development with say calf and ham string specific exercises.
Also just to note, its not like my quads hurt like they are injured, rather its like the pain you get after training any muscle. But to reiterate why I posted, my quads seem to feel this post training muscle soreness noticably more than any other leg muscle.
Anyway thanks for replying and I will try and read some google stuff....
- casual_cyclist
Postby casual_cyclist » Mon May 18, 2009 8:26 pm
Postby heliage » Mon May 18, 2009 9:01 pm
I guess it could just be that your quads are not as fit as your calves, in relation to the amount of work their doing. You can easily check if their still doing something by just putting your hand to your calf, if its hot, then its working hard.
And no expert here, but just adding muscle mass to a muscle that isnt working hard enough at the moment, will just hurt your power to weight ratio? When it is stressed when you ride more then your used to it'll naturally adapt and develop.
- eucryphia
Postby eucryphia » Mon May 18, 2009 9:02 pm
When my quads fully adapted I had trouble with my upper back/shoulder, I had to remember to keep my back straight. Then I went through a period when my hip would 'click' when trying to maintain a high cadence (front crank rpm). In between my quads would get sore again for a time.
At the moment I get sore leg and hip joints, where the tendons join my bones, my wife (takes x-rays for a living) says in old-farts like me, the tendons take longer to adapt and get stronger than muscles.
I find I need to take a week off riding occasionally or I begin a slow decline.
So ride until you puke, taking the odd week off should keep you good and sore all over, at least you'll know you're alive
Postby heliage » Mon May 18, 2009 9:40 pm
- tallywhacker
Postby tallywhacker » Mon May 18, 2009 9:50 pm
Two things I have found to help with leg strength
1. when brushing my teeth in the morning before I ride is I do single leg squats 4 sets of 20 on each leg (most probably brush my teeth too long)
2. when going up a hill I stay in the saddle
maybe right, maybe wrong but it seems to work for me
Postby the dang » Mon May 18, 2009 10:02 pm
Yeah I do ride with toe clips and straps but sometimes they are on fairly loose (when I am stop starting or in heavy traffic). Also I noticed even with the straps I still focus mainly pushing on the down stroke. I read about people saying with some form of pedal retention you are able to also pull up on the up stroke but I found when I tried this I don't put nearly as much effort in the down stroke. Its kinda like I go from one extreme to the other....maybe thats an area of pedalling technique I can improve upon.
But anyway I guess what doesnt kill my quads will make them stronger.
Tallywhacker, that is quite interesting to me, and the reason I asked the question in the first place. In my very limited knowledge of cycling and the how cycling relates to the body, I always thought quads cos its like a pushing action which I thought recruited the quads. But then I was just thinking recently, I always thought my quads were the strongest muscle in my legs and my weakeness was calves and hammies, so why do my quads seem to ache most.
Anyways I guess whatever it is, I'll just keep riding...
Postby Nobody » Mon May 18, 2009 10:52 pm
To start with, if you use the heel on pedal technique you're likely got your saddle too low. Personally, my inseam is 82. According to the 109% method I should have a saddle height of 89.4cm, but am currently using 90.6cm. See:
http://www.bikeradar.com/fitness/techni ... ight-14608
Trial and error is likely going to be the way that works for most.
Then there is the for/aft position. Some people use the KOPS (knee on pedal spindle) method to determine this. I like to play with this variable so have had my saddle as far back as 30mm behind KOPS which seemed to produce peak power well but didn't seem good for my knees. Currently it is 10mm behind KOPS and I think I may move it forward further. I've read moving the saddle back engages the hamstring more. Below are some links to Steve Hogg's bike fit articles. You may be able to glean something from it.
http://www.cyclefitcentre.com/further%20reading.htm
http://www.cyclingnews.com/fitness.php? ... e_position
As for pedaling technique itself, here is a general article:
http://www.topbike.com.au/pdfs/colson-b ... ug2002.pdf
My quads also hurt the most while pedaling hard. I hardly notice anything else. I suppose you could compare it a bit to stair climbing just with less force. Most people would expect their quads to get sore first if stair climbing.
- Alex Simmons/RST
Postby Alex Simmons/RST » Mon May 18, 2009 11:21 pm
- PeterG
Postby PeterG » Tue May 19, 2009 6:46 am
Knee over pedal axle just doesnt work for me.
- casual_cyclist
Postby casual_cyclist » Tue May 19, 2009 2:24 pm
+1Alex Simmons/RST wrote:I would suggest that if a rider is consistently having problems with one particular muscle/muscle group becoming sore, or fatigued well before others, then it's a good sign that bike fit is not right.
Postby USM TOM » Tue May 19, 2009 7:21 pm
i dont any soreness in my calves at all
- Andrew69
Postby Andrew69 » Tue May 19, 2009 7:47 pm
Try moving your cleat towards the rear of the shoe slightly.casual_cyclist wrote:Not saying this is right, but my calves are the most sore after riding.
Dont forget to drop your seat height slightly as well to compensate.
2008 Cervelo P3C
- casual_cyclist
Postby casual_cyclist » Tue May 19, 2009 10:02 pm
err... yeah... about that... I am not actually using clipless pedals. I am still old school and am riding an 18 year old bike with clips and straps. I was told a number of times of the 200km ride that I 'need' to get 'proper' shoes. However, I finished the ride comfortably, so that is obviously not true. Would 'proper' shoes and clipless pedals be more comfortable? Dunno. I have never used them. I am looking at them atm and will report back with the results. Also, when I say the most sore, my calves are not sore as in pain, but more that out of all my muscles they are the ones I can feel the most. You ride 200km and you are going to feel it somewhereAndrew69 wrote:Try moving your cleat towards the rear of the shoe slightly.casual_cyclist wrote:Not saying this is right, but my calves are the most sore after riding.
Postby Nobody » Wed May 20, 2009 8:49 am
Oh the shame of not wearing clipless. Yes, I too aspire to wearing clipless pedal/shoes and therefore becoming a "real" cyclist.casual_cyclist wrote: err... yeah... about that... I am not actually using clipless pedals.
- casual_cyclist
Postby casual_cyclist » Wed May 20, 2009 11:36 am
sigh! I know. I really don't see what the big deal is. I didn't experience much discomfort from my regular shoes and clips/straps pedals on my 200km ride. I am of the "if it aint broke, don't fix it" school of thought. That said, I will try on some 'real' shoes and see how they feel.Nobody wrote:Oh the shame of not wearing clipless. Yes, I too aspire to wearing clipless pedal/shoes and therefore becoming a "real" cyclist.casual_cyclist wrote: err... yeah... about that... I am not actually using clipless pedals.
- lemmiwinks
Postby lemmiwinks » Wed May 20, 2009 11:57 am
I only wear regular shoes for most of my riding, however the big advantage of clipless IME is hills. No flex in the soles = more power to the wheel. I could really feel it on the hills the first time I used them.casual_cyclist wrote:That said, I will try on some 'real' shoes and see how they feel.
Postby Nobody » Wed May 20, 2009 3:15 pm
There should be something to this but it would be great if people could put a real figure on it, like stiff shoes give me X and clipless shoes/pedals give me Y over using Z while doing A.lemmiwinks wrote:I only wear regular shoes for most of my riding, however the big advantage of clipless IME is hills. No flex in the soles = more power to the wheel. I could really feel it on the hills the first time I used them.casual_cyclist wrote:That said, I will try on some 'real' shoes and see how they feel.
As I've been saying I'm going to try to measure the benefit in the future.
So far the plan is to use a fluid trainer to:
One ride start with flat pedals and swap half way through the ride to SPDs.
The next ride start on SPDs then swap to flats half way though.
If I keep repeating this process and averaging the figures I should eliminate variances between good and bad days as well differences between different parts of the ride. When I've done enough rides to satisfy myself of the consistency of the recorded data I'll likely post it.
Postby Missy24 » Wed May 20, 2009 4:06 pm
It has 29 Pro Cycling Secrets for Roadies
As a newbie to cycling I found it interesting and it gave me further information to ask more question, so check it out... oh and you need to sign up for the news letter to down load it!
I loved learning how to use cleats... especially the falling off part!
Postby waynohh » Wed May 20, 2009 9:46 pm
The last thing you and we want is you doing yourself injury.
You can get reasonably priced pedals and stiff soled shoes that you can walk in for about $200 and your knees and everything else will thank you later.
Example:
PD-520 - 380g with cleats - $51
OR
PD-M520 - 430g with cleats - $40
AND
SJ-M122 - 653g - $125
Plus about $35 shipping
Total $200. Of course you'd want to know your size before ordering shoes online though, or buy them from Anaconda or somewhere like that instead.
Personally, only my rear leg muscle groups ever twinge - calves, hamstring and glutes. I never climb standing up to save my knees.
Postby Ant. » Wed May 20, 2009 10:35 pm
Oh dear.waynohh wrote:First order of business is upgrade to pedal system that you can apply power on the full crank rotation or as near as possible, not just the down stroke. Without the proper equipment it will be impossible to develop proper technique. If you can't power on the up stroke using your calves, hamstrings and glutes you're using less than half your leg and that's why your quads hurt.
Cervélo P3C
BT Blade
- All times are UTC+11:00
