ways to work out max HR (not via formula)
Postby Addict » Fri May 01, 2009 4:10 pm
Just looking for recommended ways some people use to work out their max HR, either using an indoor trainer, or on the road.
Thanks in advance.
- toolonglegs
Re: ways to work out max HR (not via formula)
Postby toolonglegs » Fri May 01, 2009 4:31 pm
I only ever hit my max (190 (seems to have dropped 4 beats over the last few years)) in a sprint at the end of a hard race when I am in a reasonable refreshed state to start with.
Postby Addict » Fri May 01, 2009 4:34 pm
how do u go about doing it on an indoor?
looking for guidance or the steps to work out my own properly..
eg warm up 10mins, effort, rest effort rest etc?
is there a particular gear u should do this on? eg 52/12..?
- toolonglegs
Postby toolonglegs » Fri May 01, 2009 4:44 pm
- Alex Simmons/RST
Postby Alex Simmons/RST » Fri May 01, 2009 5:27 pm
OK, warning messages aside, then, on a day when you are not fatigued, after a good solid warm up of 20-30 mins:
- indoors, perform a ramp test with the resistance continually increasing every 1-2 minutes and keep pushing through until you can no longer sustain an ever increasing load, and give it everything you have for those final 30 seconds.....
- outdoors, find a long hill (> 5 minutes, 10min is better) and go up it very hard, sprinting the final 200 metres to the top
Max HR will likely occur shortly after the effort has finished.
These are not perfect but should provide the stimulus needed to induce Max HR, or very close to it.
Then, for very hard efforts, such as after a long sprint at end of a hard race, you can compare to see if you get similar values.
Postby Addict » Mon May 04, 2009 10:09 am
- sogood
Postby sogood » Mon May 04, 2009 10:33 am
... And hope it doesn't brings on an attack of tachyarrhythmia.
Disclaimer: It's a potentially dangerous and fatal procedure if not carried out under proper medical supervision.
Postby Nobody » Mon May 04, 2009 12:49 pm
Postby USM TOM » Tue May 05, 2009 9:27 am
- sogood
Postby sogood » Tue May 05, 2009 9:36 am
Easy and HRmax don't equate.USM TOM wrote:would it be easier to find your max heart rate doing something that you dont train for like doing a sprint (running)
Postby USM TOM » Tue May 05, 2009 11:23 am
- Alex Simmons/RST
Postby Alex Simmons/RST » Tue May 05, 2009 1:36 pm
As a proxy estimate sure but it is far better to test in sport specific mode.USM TOM wrote:i know it still wouldnt be easy but im sure i'd get my heart rate pumping quicker running then i would cycling because im so bad at it
As an example, use of upper arms can readily increase HR substantially, over that when using legs primarily.
An alternative is to ascertain your average HR from a time trial effort, and base training levels on that instead:
http://home.trainingpeaks.com/articles/ ... evels.aspx
Postby USM TOM » Tue May 05, 2009 2:33 pm
i supose the more muscles you recruit the harder your heart would have to workAlex Simmons/RST wrote:USM TOM wrote:
- casual_cyclist
Postby casual_cyclist » Tue May 05, 2009 2:53 pm
This is true. I have to work pretty hard to get my heart rate up when cycling but when I am running it goes up so high that I feel like I am going to pass out after 4 mins (1 km). I have never felt like I was going to pass out when cycling (which is lucky I suppose).Alex Simmons/RST wrote:As a proxy estimate sure but it is far better to test in sport specific mode.USM TOM wrote:i know it still wouldnt be easy but im sure i'd get my heart rate pumping quicker running then i would cycling because im so bad at it
Postby DuncanS » Wed May 06, 2009 11:45 pm
Here's an interesting reference:
http://home.hia.no/~stephens/hrchngs.htm
- Alex Simmons/RST
Postby Alex Simmons/RST » Thu May 07, 2009 12:02 am
Something to do with inter arterial blood pressure being higher in arms (than legs) for same level of oxygen uptake. That's why for instance doing work involving arms, like digging, shovelling etc is not recommended for those with heart problems.USM TOM wrote:i supose the more muscles you recruit the harder your heart would have to workAlex Simmons/RST wrote:As an example, use of upper arms can readily increase HR substantially, over that when using legs primarily.
- sogood
Postby sogood » Thu May 07, 2009 7:32 am
Not sure I'd explain it that way. There's arterial damping further down the body (to LLs), but mean pressure stays. The impact on the rate of HR change (cardio load) can probably be better explained by the much greater number of muscle groups involved and the combined rate of energy use of this greater muscle mass. The question for the cyclists is, can the combined work load (of the muscle mass needed for cycling) induce the heart to reach its max response, or are there local (neuro/muscular) limitations that restrain that?Alex Simmons/RST wrote:Something to do with inter arterial blood pressure being higher in arms (than legs) for same level of oxygen uptake. That's why for instance doing work involving arms, like digging, shovelling etc is not recommended for those with heart problems.USM TOM wrote:i supose the more muscles you recruit the harder your heart would have to workAlex Simmons/RST wrote:As an example, use of upper arms can readily increase HR substantially, over that when using legs primarily.
- slane
Postby slane » Fri May 08, 2009 4:43 pm
In a post by a very fat lady, she said she'd been watching Hidalgo, while pedalling her exercise bike and, during the thrilling finale, accidentally reached 178bpm, which is her maximum, and she was worried she'd damaged her heart.
I thought .. "oh dear! do I tell you" and then decided she wouldn't believe me if I told her.
- All times are UTC+11:00
