Headwinds!
Ant.
Headwinds!
Postby Ant. » Fri May 01, 2009 3:53 pm
After crashing my TT bike (AT) 70kph, netting a broken frame, broken wrist, broken pride and suspected broken T5 (got cleared of that yesterday! :D :D ), I figured I needed these.
So have you ever had to wear armwarmers whilst on the indoor trainer? :shock:
Good old Bunnings - comes through with the goods. I can't recommend these bad boys high enough if you're forced to do indoor riding, like I am right now.
Cervélo R3
Cervélo P3C
BT Blade
Re: Headwinds!
Postby toolonglegs » Fri May 01, 2009 3:57 pm
I thought you had them wall mounted for a second :D .
sogood
Re: Headwinds!
Postby sogood » Fri May 01, 2009 4:05 pm
OMGosh! You totaled your Cervelo? :shock:
Bianchi, Ridley, Tern, Montague and All things Apple :)
Re: Headwinds!
Postby toolonglegs » Fri May 01, 2009 4:34 pm
sogood wrote:OMGosh! You totaled your Cervelo? :shock:
I don't remember you even crashing...was there a post?.70kmph is motorbike stuff....scary!.
Alex Simmons/RST
Re: Headwinds!
Postby Alex Simmons/RST » Fri May 01, 2009 5:11 pm
Holy crap - just saw this!!
Is the power meter OK? :D
OK, bad humour. Heal fast Ant. That's a shocker.
Nice fans. You'll need 'em
Ant.
Re: Headwinds!
Postby Ant. » Sat May 02, 2009 10:04 pm
There was no thread - I had better things to do than recount what happened!
Actually, the radiologist got it wrong... wrist isn't broken. At that speed, at the swelling my wrist was at, and the soreness, and because i'd had surgery on the wrist before, they were 'looking too hard' for a fracture or something. From an X-ray and CT scan, the radiologist was convinced posterior distal aspect of right radius was fractured (non displaced), and one orthopaedic surgeon agreed based upon the CT scan.
Turns out it's just the epiphyseal (sp?) fusion joint :-D (according to a much better orthopaedic surgeon)
So transverse process of T5 didn't get cracked, wrist didn't get broken... apart from general htfu soreness and these tree splinters I'm still slowly picking out of my calf, i'm fine?! :shock: people actually die at slower speeds than that, and I'm unscathed... I don't have the words for that.
P3 is totalled :cry:
Cervélo R3
Cervélo P3C
BT Blade
sogood
Re: Headwinds!
Postby sogood » Sat May 02, 2009 11:24 pm
P3... RIP. :cry:
Ant.
Re: Headwinds!
Postby Ant. » Sun May 03, 2009 3:13 pm
I'm not ready to update my signature yet :(
Cervélo R3
Cervélo P3C
BT Blade
