Cheaper cassettes
Cheaper cassettes
Postby warthog1 » Thu Jul 11, 2024 7:45 pm
I ended up ordering the wrong one . The one I got has the largest (low) gears made from a block of aluminium.
They are thicker than the other individual smaller (tall) gears. It shifts fine and rides fine, but it remains to be seen how long the aluminium gears last. Still they have more teeth to spread the load and chainrings last ages and are aluminium so we will see. I will report back.
I have ordered another in steel as I originally wanted.
I have been running Sunrace cassettes in 11s on my other bikes for some time and they have been fine. Will see how these ZTTO goers compare.
Sunrace do have a 12s cassette in the right range but it aint light or particularly cheap.
https://sunrace.com/product/csrz800-wav/
Re: Cheaper cassettes
Postby CmdrBiggles » Thu Jul 11, 2024 7:55 pm
'tis a near-perfect colour combo match for my 1984-vintage ConFest (AT) Everton tie-dyed (and tatty) T-shirt.
If SRAM gets on board with this wild retro-hip colour job, I'm in!
- Duck!
Postby Duck! » Thu Jul 11, 2024 10:15 pm
Postby 2wheels_mond » Thu Jul 11, 2024 10:31 pm
For cassettes, I'd add 'good shifting' into that as well, and choose three. Cassettes are very reliant on meshing with chain profiling, particularly on 12 speed.
I've had no trouble (for a very short time of use) using a 10 speed cassette from AliExpress (branded as Sensah, but seemingly the same one also often branded 'Sunshine' and a few others on AliExpress). For 12 speed though, the tighter tolerances I expect leave less room for error.
A few experiences here from the Chinertown forums were not all that positive on the 12 speed versions of the monoblock cassettes like the one in Trace Velo's video when used with Shimano 12 speed:
http://chinertown.com/index.php/topic,3897.60.html
Postby warthog1 » Thu Jul 11, 2024 10:41 pm
It is shifting fairly well so far, but yes not as good as the shimano cassette on my other wheel. Still satifactory however. No failed changes, just not as snappy. Will see if that remains the case.
- elantra
Postby elantra » Sat Jul 13, 2024 12:58 am
2wheels_mond wrote: ↑Thu Jul 11, 2024 10:31 pmFor cassettes, I'd add 'good shifting' into that as well, and choose three. Cassettes are very reliant on meshing with chain profiling, particularly on 12 speed.
Personally I really prefer my shifts to be “clunky”
As far as I am concerned the Shimano 9-speed (and greater) systems are disappointingly smooth and seamless.
So I prefer the cogs on cassettes and freewheels to NOT have those little ramps.
It’s actually more than just subjective- being able to unmistakably hear the shifts being completed is very beneficial if using friction (not indexed) shifters.
Confessions of a Retro-grouch ?
Actually I do prefer indexed shifters, but sometimes when your bike has a mismatch of Suntour, Shimano, and Campagnolo components from different eras in the drivetrain - that’s the only way to make it work !
- g-boaf
Postby warthog1 » Sat Jul 13, 2024 1:36 pm
- g-boaf
Postby g-boaf » Sun Jul 14, 2024 5:17 am
The cassettes were great for getting their bike down to a particular weight but not suitable for spirited riding. Cannot remember the brand of cassette as it was many years ago.
Postby warthog1 » Sun Jul 14, 2024 5:59 am
- WyvernRH
Postby WyvernRH » Mon Jul 15, 2024 11:29 am
Being ignorant, what/where are 'WW Forums' ??
I'm assuming it relates to 'Weight Watchers' or Weight Weenies' and refers to the bike not the rider?
Going back to freewheel days, IIRC Campag had a freewheel with hardened aluminium cogs for the weight conscious. Worked fine til you wore thru the hardened layer and then it all went to hell. Good for a stage or two but that was all. Others tried to copy this (Sachs/Maillard maybe?) but that was a disaster. Not only was the hardening substandard and wore quickly but the body/cog interface was not as well designed so under heavy load the cogs ripped off the body allowing free rotation. Not good when out of the saddle.
One fashion that died very quickly....
- g-boaf
Postby g-boaf » Mon Jul 15, 2024 11:36 am
Weight weenies forum. I think some of the riders on there are also equally as light as the bikes. But I'm not a member of that forum and rarely look at it.
Postby warthog1 » Wed Jul 17, 2024 5:19 pm
Postby warthog1 » Wed Jul 24, 2024 7:06 pm
One gear wont drop down reliably yet if I adjust it the other way, another wont step up reliably. Not terrible enough to take it off but annoying enough that I wouldn't get another. The aluminium gears at the top of the cassette shift fine.
Having said I wouldn' t get another I did order the one I was after originally. All steel. Based on my experience of the other where the steel teeth are the problem I am not expecting much.
Postby blizzard » Wed Jul 24, 2024 10:14 pm
Postby warthog1 » Wed Jul 24, 2024 11:06 pm
I don't really understand how their branding goes then?
I guess you are saying ztto are just an umbrella for a number of factories to flog their gear off?
It'll be a while until I try it, unless the average shifting on the original one does my head in and I bin it.
Entirely possible I guess.
Postby blizzard » Thu Jul 25, 2024 7:47 am
Pretty much, I think Ztto is a legit brand but they will find factories making a product and pay them to brand it Ztto. My experience with Ztto is that they are generally good quality. Cassettes are a bit harder because Shimano has the patent on HG teeth etc.warthog1 wrote: ↑Wed Jul 24, 2024 11:06 pmI don't really understand how their branding goes then?
Life is too short for poor shifting, I would be changing the cassettes over at least to try at the first opportunity, and run whatever shifts best.
- Jean
Postby Jean » Thu Jul 25, 2024 8:59 am
blizzard wrote: ↑Thu Jul 25, 2024 7:47 am
I'm pretty sure the Shimano HG patents would have expired by now, it's been around for ages. A quick internet search suggests this is the case https://www.bicycleretailer.com/opinion ... s-flourish.
So any dodgy Chinese shifting is probably more about their capacity or willingness to emulate it at a cheaper price point.
Postby warthog1 » Sat Jul 27, 2024 2:09 pm
Rewaxed chain on yesty and swapped the steel/ aluminium cassette for the all steel one.
It takes a few ks for a newly waxed chain to free up and shift perfectly ime, so not sure how it is yet. Woeful weather today, hopefully I can get another ride in tomorrow. I will report back how it rides/shifts with a 12s shimano chain.
The steel/aluminium one I have got about the best I can. Gear 8 》9 doesn't shift down immediately. A full crank spin or two as it clicks away without shifting. However at the same time 11 》 10 is hesitant to go back up the cassette and is almost the same. So if I adjust the derailleur further down the cassette that shift up won't work.
I did note when I took the cassette off the lock nut came off with not much force. I definitely torqued it to at least 40nm with a 1/2" drive torque wrench when I installed it. Dunno if torqueing it back up would have helped?
Set the torque wrench to about 45nm installing the new one.
Postby enerondondon » Sun Jul 28, 2024 1:29 am
Postby warthog1 » Sun Jul 28, 2024 4:14 pm
Prompted by another thread I checked the B screw adjustment.
https://bettershifting.com/installation ... ent-guide/
Yep a little bit too much clearance. I gave it more when I went from 30-11 to 34-11.
Wound it a few mm closer. Stopped twice on the ride to adjust the derailleur. Moved it a total of 3 clicks further out. It is shifting pretty well on all gears. Just gear 9 》10 takes a slight hesitation to drop down. All shift up fine. Might give it one more click before the next ride.
Got me stuffed why I needed to click it further outboard than the previous cassette on the same hub?
Anyway, if it keeps shifting well and proves durable I would get this cassette again. Will see how it goes and report back.
Postby warthog1 » Sun Aug 04, 2024 3:32 pm
Double Mt Alex today on the WRs with the steel Ztto cassette.
Shifting is pretty close to the 105 cassette. Certainly good enough for me.
If it remains durable then it will be my go to cassette.
- rangersac
Postby rangersac » Tue Aug 13, 2024 8:40 am
- All times are UTC+11:00
