Cycling computer through the wash
warthog1
Postby warthog1 » Sat Jun 22, 2024 6:45 pm
Yep, not my greatest moment :roll:
Had my edge 1030+ in my jacket pocket ready for a wash. Stripped off and bunged all my gear in the wash. Without taking the 1030 out of my pocket.
The screen is now nice and clean. :wink:
Have it in a bowl of rice in front of the fire. I wont be turning it on for at least 24h. Any other ideas?
I expect it is toast. Bloody good computer that is not that old. It was a refurbished unit that has been great. Back to the 1000 whilst I look for another most likely. :(
am50em
Re: Cycling computer through the wash
Postby am50em » Sat Jun 22, 2024 7:01 pm
IPX7 so maybe will survive. You could open the case.
warthog1
Postby warthog1 » Sat Jun 22, 2024 7:06 pm
Thank mate :)
Hopefully it does survive.
Not going to try to open it. Guaranteed to be broken with passion fingers here, trying to prise the screen free. :oops:
am50em
Postby am50em » Sat Jun 22, 2024 7:14 pm
A phone repair shop should be able to do it.
warthog1
Postby warthog1 » Sat Jun 22, 2024 7:40 pm
Good idea. Will give it a sit in front of the heater in rice and see how it goes.
foo on patrol
Postby foo on patrol » Sat Jun 22, 2024 9:53 pm
:lol: :lol: Give yaself an uppercut! :wink:
Foo
Goal 6000km
Postby Duck! » Sat Jun 22, 2024 10:06 pm
On Rotorburn there is a thread titled "Confessions From The F*@kwits" for incidents like this. :P
warthog1
Postby warthog1 » Sat Jun 22, 2024 11:11 pm
Yep guilty :( :oops:
Pissed me off too. Be surprised if it works again. I'll ring Garmin service and see what they say, may be able to send me another refurbished one if it is toast. Hopefully cheaper than a new 1040. Dont want to go smaller screen and love the battery life on this one
warthog1
Postby warthog1 » Sat Jun 22, 2024 11:23 pm
I looked up IPX7
The second digit in an IP rating signifies the degree of protection against water and moisture. Like with the first rating digit for solids, higher numbers indicate a higher level of protection. This scale ranges from 0 (no protection) to 8 for the highest level of protection. For instance, with an IPX4 rating your earbuds are protected against splashing water from any direction. On the other hand, an IPX7 rating ensures that the device can be submerged in water up to 1 meter for 30 minutes without any damage. This level of protection is ideal if you feel like taking your earbuds with you for a quick swim.
https://www.jabra.com/blog/waterproof-o ... ick%20swim.
Hmm. I'll be surprised but we will see.
Thanks am :)
warthog1
Postby warthog1 » Sun Jun 23, 2024 3:45 pm
Well I used the old edge 1000 today. Still works. Battery was flat after not being used since Oct '22 but charged ok. Perhaps the battery is past its' best. ~13% battery used per hour with radar and PM pedals connected. The 1030+ uses les than 3% per hour.
Had trouble uploading the ride though. Connected it to my phone multiple times but it kept dropping out. Connected it to wifi. Nup wouldn't upload. As we all know, unless a ride is on Strava it didn't actually happen. :wink: :lol:
Anyway after I got frustrated at the lack of success I decided to plug it into the computer. Logged onto Garmin express and there the edge 1000 is "retired". Deleted it and jumped back on Garmin Connect on my phone and added it again. Success! Uploaded. :)
In the midst of trying to connect and getting frustrated, bugger it I turned the edge 1030+ on :o
Yes!! Started up as normal and is now on charge! :D :D
Very happy with that. A stupid proof device it seems to be. :wink: :oops:
am50em
Postby am50em » Sun Jun 23, 2024 3:46 pm
Good result!
warthog1
Postby warthog1 » Sun Jun 23, 2024 3:51 pm
Yep, very impressed with that! It aint going to bat its' eye at riding in any sort of rain. 45minutes in a washing machine with detergent added. It was a cold wash though. :lol:
CmdrBiggles
Postby CmdrBiggles » Sun Jun 23, 2024 4:18 pm
If the charge port bung was in place, it is a non-event, in cold water.
If it had been a hot wash, that would delaminate the screen and burst the LCD matrix = buy a new 'puter...
I've had a pricey Tissot watch left in a jumper pocket go through the cold water (40 minutes; I never use hot water in the wash) and all that did was the detergent ruining the napa leather band.
Phones though are much less amenable to being put in a spin, at any temperature, for any length of time. My first iPhone came to grief way back in 2010.
GIANT '24 TCR Adv. Pro Disc 0-AR/ SRAM Force eTAP
2022 Dragon Raptor e-scooter ['Yellow Peril']
warthog1
Postby warthog1 » Sun Jun 23, 2024 4:30 pm
The charge port cover is just a clip in plastic part. It was moist inside. I am assuming the plug inside is sealed against water entering the housing.
CmdrBiggles
Postby CmdrBiggles » Sun Jun 23, 2024 4:34 pm
Oh!
I would go a step further and use a vacuum cleaner against the port to suck out any moisture you can see or feel.
Maybe a wet-dry vac, just in case the unit springs a surprise on you with a torrent of water!!
JPB
Postby JPB » Sun Jun 23, 2024 6:52 pm
I once accidentally put my Garmin heart rate monitor through the wash. It survived, but it is a lot more robust than a cycling computer.
warthog1
Postby warthog1 » Sun Jun 23, 2024 7:02 pm
As per am50em it is supposed to be IPX7 rated. Turns out that wasn't a lie. :)
antigee
Location: just off the Yarra Trail but not lurking in the bushes
Postby antigee » Sun Jun 23, 2024 7:05 pm
sounds good
left my Varia in pocket and washed it ... all was good...mind you only a 15min cycle at 20degs as that's what I use for sports stuff and works fine....machine has a "sports cycle" 40mins at 30degs seems a bit excessive unless you have teenage young men
