cassette alignment
cassette alignment
Postby warthog1 » Wed Jun 12, 2024 9:38 am
Put it on the Reynolds rear wheel the bike came with and it shifts perfectly.
Took a photo this am and it seems the cassette alignment between the 2 hubs is significantly different. I guess I can learn to retune the di2 for the different cassette alignment but would rather they just be in the same spot
Anyone got any ideas what is going on here and how to fix it?
- biker jk
Re: cassette alignment
Postby biker jk » Wed Jun 12, 2024 10:34 am
- elantra
Postby elantra » Wed Jun 12, 2024 1:49 pm
Can you use spacers on one of the hubs to make the distance from the smallest cog to the derailleur exactly the same for both - and then tube the Di2 to this new setting ???
- Thoglette
Postby Thoglette » Wed Jun 12, 2024 2:56 pm
On traditional hubs one can add/delete washers between the drive side bearing cone and the locknut to adjust the location of the gear set relative to the frame and thus the derailleur.
Is something similar possible with either of your wheels?
Postby warthog1 » Wed Jun 12, 2024 3:41 pm
Forgot to hit save when editing to add photo I think. Been for a ride.
Had the cassette off several times. No washers there, 11t gear is in correctly.
I have two sets of wheels with DT350 hubs. Have used both on the Revolt with 11s and they are spaced the same and shift the same.
As per the photo the hub on the Reynolds wheel has more axle protruding so means the cassette is more inboard vs the derailleur. Maybe the hub on the Reynolds wheel can be adjusted or the cassette spaced out? I don't think the DT350 can.
Postby warthog1 » Wed Jun 12, 2024 3:46 pm
That might be a solution
Postby blizzard » Wed Jun 12, 2024 4:01 pm
Also 12sp Shimano cassettes have a adhesive ring behind the last gear that is sometimes missing, but I don't think it would cause any misalignment as you can remove them and run the cassette fine.
Postby Mr Purple » Wed Jun 12, 2024 4:15 pm
You should be able to space one to make it identical to the other, but I'd imagine it's pretty fiddly!
I've had this issue swapping bikes on and off the trainer.
- foo on patrol
Postby foo on patrol » Wed Jun 12, 2024 6:54 pm
Foo
Goal 6000km
Postby warthog1 » Wed Jun 12, 2024 6:57 pm
Yes, that is the 11-30 on the dt350 in the photo. I had a good look for any spacers but it shifts perfectly on the Reynolds. Did 120k on it today.blizzard wrote: ↑Wed Jun 12, 2024 4:01 pmMaybe a dumb question, does swapping cassettes so the old one is on the DT350 yield the same issue?
Love the gearing of the 11-34 with the 52/36 rings
Postby warthog1 » Wed Jun 12, 2024 7:02 pm
They shouldn't be different but they are are. Yeah will see if I can find a 10s spacer in my boxes of sh it and see how that goes.
Postby warthog1 » Wed Jun 12, 2024 7:03 pm
Yeah it may be less than 1.85mm. Good idea.foo on patrol wrote: ↑Wed Jun 12, 2024 6:54 pmSpacer ring but also measure the distance from the top cog to the lug and that should tell you the dfference.
Foo
- Duck!
Postby Duck! » Wed Jun 12, 2024 7:32 pm
Postby warthog1 » Wed Jun 12, 2024 7:39 pm
Bugger!Duck! wrote: ↑Wed Jun 12, 2024 7:32 pmIt's quite common for different brand hubs to have different offsets, however that is a bit more pronounced than usual. DO NOT put spacers where they are not specified; it can lead to insufficient lockring thread engagement, which can lead to freewheel body damage.
Thankyou, for the advice coming from experience.
- Duck!
Postby Duck! » Wed Jun 12, 2024 8:00 pm
Postby warthog1 » Wed Jun 12, 2024 8:04 pm
Just had a look at a Sun Ringle maintenance document and there is no adjustment.
https://www.google.com/url?sa=t&source= ... JG1MRJBWmL
Postby warthog1 » Wed Jun 12, 2024 8:09 pm
May need to adjust the limit screw at the bottom too maybe.
- Duck!
Postby Duck! » Wed Jun 12, 2024 8:37 pm
So you can afford to back both limits out a bit; set the low (inner) to suit the more inboard Reynolds/Ringle hub, and the outer limit for the DT, then just use your micro-tune to adjust between the two wheels. Once you've done it a few times you'll know how many clicks are needed to adjust for each wheel.
Postby warthog1 » Wed Jun 12, 2024 8:44 pm
- open roader
Postby open roader » Fri Jun 21, 2024 6:27 pm
Postby warthog1 » Fri Jun 21, 2024 8:31 pm
I might be n-1 for somewhere to live if I did that though, so soon after buying an expensive bike
- foo on patrol
Postby foo on patrol » Fri Jun 21, 2024 9:20 pm
Foo
Goal 6000km
- All times are UTC+11:00
