I'm looking for recommendations for an ebike that I can take on NSW long distance trains, which means it has to be under 20kg, excluding a removable battery that I will pack separately.
From the NSW Transport website
https://transportnsw.info/travel-info/u ... -trainlink
- Push bicycles are accepted on NSW TrainLink services
- Bicycle must be contained in a bicycle box to protect the bicycle.
- Bicycle box must be no larger than 135cm long x 80cm high x 24cm wide.
- The container needs to be less than 20 kg in weight to be accepted.
- Folding bicycles must be packed in a protective cover and be no larger than 79cm long x 59cm high x 36cm wide.
