Recommend me a Phone/Tool holder pouch. Please
- MichaelB
Postby MichaelB » Mon Nov 21, 2022 4:04 pm
The Sticky Pod that I've been using for a while is about to die, and with a new phone coming along shortly (prob a iphone 13/14 Mini), can anyone recommend me an affordable and quality holder that can take the phone, keys and a few cards etc.
Max budget is about $60 -
Hit me up with your recommendations !!
Re: Recommend me a Phone/Tool holder pouch. Please
Postby lone rider » Tue Nov 22, 2022 7:20 pm
- trailgumby
Postby trailgumby » Tue Nov 22, 2022 8:35 pm
- AUbicycles
- Site Admin
Postby AUbicycles » Wed Nov 23, 2022 4:49 am
- MichaelB
Postby MichaelB » Wed Nov 23, 2022 9:19 am
Sounds like a good idea - I'll investigate that option tootrailgumby wrote: ↑Tue Nov 22, 2022 8:35 pmI split my phone, cards etc from my tools/CO2/tyre levers pouch, placing the phone in the left jersey pocket and the pouch in the right, leaving the middle pocket for nutrition product. Otherwise, the combination is too heavy and slides to one side, twisting up my jersey.
Hiya Chris, have a Zilfer sitting there and issue is that I'll be using a case protector on the phone which is what traditionally creates issues.AUbicycles wrote: ↑Wed Nov 23, 2022 4:49 amI can bring you a Zilfer. It is not zippable or waterproof like a pouch but keeps stuff nicely together. Think the iphone 13 and 14 regular sizes will fit… but not with the phone protector and that is where it is then an issue and a hard case is essential for me.
@lone rider - I'll look at those two options as well, thanks
- trailgumby
Postby trailgumby » Wed Nov 23, 2022 9:41 am
MichaelB wrote: ↑Wed Nov 23, 2022 9:19 amSounds like a good idea - I'll investigate that option tootrailgumby wrote: ↑Tue Nov 22, 2022 8:35 pmI split my phone, cards etc from my tools/CO2/tyre levers pouch, placing the phone in the left jersey pocket and the pouch in the right, leaving the middle pocket for nutrition product. Otherwise, the combination is too heavy and slides to one side, twisting up my jersey.
A couple of additional comments might be of interest. Crashes can happen despite best intentions so I never put anything hard in my centre pocket as that sits over my spine. While the probability is low, the consequences are potentially very high.
As for water resistance, I just use ziplock bags. Maybe not as elegant, but they weigh almost nothing, don't need to be maintained, and when they stop being waterproof they cost cents to replace.
- Retrobyte
- familyguy
Postby familyguy » Wed Nov 23, 2022 11:26 am
https://stickybottle.com.au/collections ... 4503620651
I resorted to making one just so I could leave the case on the phone. An old nylon sail, the trusty Elna, and a little trial and error. It's not waterproof or padded, but V2 might be if I can get some time and suitable materials.
- MichaelB
Postby MichaelB » Wed Nov 23, 2022 4:21 pm
The Rapha one has been reviewed and recommended in an online review when CT was good.familyguy wrote: ↑Wed Nov 23, 2022 11:26 am..
I have a Sticky Pod now, and that's been good, but the plastic sleeve inside has died, mind you it's a few years old now !!
Cheers, have used a Velopac before, but zip failed after 12 mo.
- MichaelB
Postby MichaelB » Tue Dec 13, 2022 10:56 am
Ended up going with the Silca Borsa, so thanks.lone rider wrote: ↑Tue Nov 22, 2022 7:20 pmIve had a few, problem is every new phone outgrows them. Currently using a Silca Borsa, not cheap but the only thing I could find in the size I needed, been pretty durable but its probably the biggest thing I could fit in a jersey pocket. I saw some on the Pedal Mafia site yesterday that were cheap, 2 different sizes.
Yep, not cheap, but decided to treat myself a bit
- MichaelB
Postby MichaelB » Mon Dec 19, 2022 3:09 pm
PFBB
The phone + case is a smidge too big to fit in.
I can get it in, but it's too tight. So, back it's going.
The frustrating thing is that the sizing is no accurate where listed, as the internal; dimension is the key, and also, for many others, they don't list the size !!??
Postby lone rider » Mon Dec 19, 2022 4:32 pm
Probably a wise choice. Im using 6.4 inch phone and it only just fits and with the Borsa being made out of rubber tube material it doesnt have much give, the stitching would likely break if forced. I havent seen many holders much bigger than this and its at the point where its a tight fit to get into a jersey pocket. Phone screen size is now a critical factor when new phone shopping unless I go down the handlebar bag path.MichaelB wrote: ↑Mon Dec 19, 2022 3:09 pmPFBB
Postby warthog1 » Mon Dec 19, 2022 5:08 pm
That is very annoying
PFBB?
http://acronymsandslang.com/PFBB-meaning.html
Press fit bottom bracket?
It has got me sorry
- Tim
Postby Tim » Mon Dec 19, 2022 5:13 pm
warthog1 wrote: PFBB?
It has got me sorry
PFBB Plumbing Factory Brass Band
- MichaelB
Postby MichaelB » Tue Dec 20, 2022 2:30 pm
Poo Fark Bugger Bottom
- MichaelB
Postby MichaelB » Wed Dec 21, 2022 9:02 am
It's been posted back and will get refunded.lone rider wrote: ↑Mon Dec 19, 2022 4:32 pmProbably a wise choice. Im using 6.4 inch phone and it only just fits and with the Borsa being made out of rubber tube material it doesnt have much give, the stitching would likely break if forced. I havent seen many holders much bigger than this and its at the point where its a tight fit to get into a jersey pocket. Phone screen size is now a critical factor when new phone shopping unless I go down the handlebar bag path.
It is a nice pouch though, so it was a pity. A key thing is that the phone needs to be easily removeable, so the hunt goes on.
- baabaa
Postby baabaa » Thu Dec 22, 2022 12:53 pm
Have not had my one take in any moisture during this wet year - a good company who make long lasting stuff that can be repaired so worth supporting
https://cactusoutdoor.co.nz/collections ... tinder-box
Postby Andy01 » Thu Dec 22, 2022 7:54 pm
https://www.bicyclesuperstore.com.au/pr ... toQAvD_BwE
For interest - my phone etc was in this bag when I had a head-on crash with a Ford Territory SUV last year. The bag was safely attached to the bike and it's contents (incl phone) were unharmed - in spite of the Norco hard tail being a write-off.
- MichaelB
Postby MichaelB » Thu Dec 22, 2022 10:21 pm
- MichaelB
Postby MichaelB » Mon Jan 02, 2023 2:14 pm
Ended up ordering 2 off (a good deal) the Muc Off Rainproof wallets.
13 with a decent case fits fine and has a small zip pouch on one side. Could be a smidge bugger, but otherwise OK.
From Amazon in UK for $37 ea delivered
- All times are UTC+11:00
