Recommend some quality pads for v-brakes
Retrobyte
Postby Retrobyte » Mon May 02, 2022 9:40 pm
The new Shimano S65T pads I bought for my Specialised Sirrus flat bar commuter lasted 3 weeks in wet and muddy conditions. The fact that I'm not a lightweight and was lugging some weight in a pannier bag with a bit of stop/start for traffic lights probably meant they were working hard at times, but I would have expected them to last longer than this - they went from brand new to be fully worn out in that time period. Brakes were set up properly with no rubbing.
I picked up some Shimano Deore pads on the weekend and replaced them, but am now starting to geek out about whether there are better pads out there I can try when these wear out. Rims are aluminium (Pro Lite - Kotavelo). I guess I'd like a combination of both good stopping ability and reasonable wear, if that's possible.
Re: Recommend some quality pads for v-brakes
Postby Duck! » Mon May 02, 2022 10:30 pm
No brake pads will last very long under the conditions you describe.
Thoglette
Postby Thoglette » Tue May 03, 2022 9:07 am
What Duck says. There’s a reason bus & garbage truck operators spend a lot on brake spares
But Koolstop Salmon is the traditional answer.
Also, don’t “ride” the brakes when going down hill: that puts a lot of work through the brakes( better to brake hard for a while then coast).
If the bike is muddy at the end of the ride, wash the crap off.
Finally, check your rims for wear every time you change pads
Retrobyte
Postby Retrobyte » Tue May 03, 2022 10:05 am
Thanks. I have been hosing the bike down when I get home from work, and once a week do a proper clean and lube. The bike paths on my commute still have dirty water flowing across it in places so it's been an abnormal commute environment lately. I've ordered some Kool Stop pads so will give them a shot too, thanks for the suggestion.
baabaa
Postby baabaa » Wed May 04, 2022 1:39 pm
Suggest you try and find solid block pads like these if you want long lasting pads
http://www.koolstop.com/english/scottcant.html
Have had some cx canti pads wear out very quickly because they are designed to do just that - the gutters on the pads work to shed mud and slush and still stop
The old Scott Mathauser pads did last for a long time under the conditions you describe but they are no longer made - used them with canti brakes and think that a solid pad with v-brakes should offer enough power to get enough stopping grunt even if you are beefy and carry a load.
mikgit
Postby mikgit » Thu May 05, 2022 7:36 pm
Didnt the Scott Mathauser pads became the Koolstop Scott pads after koolstop bought them up? But I don't think those ones fit v-brakes, too high profile (but I guess depends on the setup..)
I like koolstop, but have also found swissstop to be great.
Fat Chance Yo Eddy 2.2, Intense Sniper XC Pro, Look 675, Cervelo R3, GT Xizang, GT Zaskar, Yeti ARC, DiamondBack Apex
Thoglette
Postby Thoglette » Thu May 05, 2022 8:32 pm
Koolstop make a huge range of pads and inserts, not just the classic Mathauser ones. But salmon is still the secret sauce
warthog1
Postby warthog1 » Thu May 05, 2022 9:45 pm
I don't have any very helpful suggestions for that bike sorry.
Disc brakes will be a better solution for the next one
Postby Duck! » Thu May 05, 2022 11:34 pm
Canti vs V-brake compatibilty is more to do with threadless or threaded post mounting rather than pad profile. There are exceptions on both sides, but generally-speaking, cantis use threadless-post pads, while V-brakes use threaded posts.
Threaded-post pads use dish & dome washers to adjust toe angle; the dished washers are unequal thickness, so can be flipped between inner & outer placement to tune the caliper setup.
Retrobyte
Postby Retrobyte » Sat May 07, 2022 10:35 am
Yes, that's my medium term plan - to buy a second hand gravel bike as my commuter to replace the Sirrus. I'm selling some non-bike related stuff to fund that purchase.
