Upgrading wheels on a Giant Defy 2021 - options
Postby coffeeallday » Mon Jan 03, 2022 8:43 pm
- elantra
Re: Upgrading wheels on a Giant Defy 2021 - options
Postby elantra » Mon Jan 03, 2022 10:14 pm
https://www.bicycles.net.au/forums/vie ... p?t=104715
The respondents above have more knowledge about lightweight disc wheelsets than I do, but I am thinking that a carbon fibre wheelset would give significant weight savings over your current wheels, which I am assuming are alloy.
Postby warthog1 » Thu Jan 06, 2022 9:47 am
https://www.this link is broken.au/prime-rr-50-v ... ess-bundle
They have been a great wheelset and frankly an absolute bargain.
The disc version are a touch heavier but that will be at the hub that matters less.
Can't go wrong at that price imo.
You need to but tubeless valves also as they aren't included and I expect discs.
- cyclotaur
Postby cyclotaur » Thu Jan 06, 2022 3:29 pm
They save about 450g overall, I run 28s instead of the 32s that are on the standard Scott wheelset, and they are stiffer, meaning better power transfer and better handling. They also run and roll better so less effort needed to get/keep the bike moving.
My old blog - A bit of fun
Postby blizzard » Sun Jan 09, 2022 7:24 pm
Postby coffeeallday » Mon Jan 10, 2022 9:51 pm
- Duck!
Postby Duck! » Mon Jan 10, 2022 11:10 pm
Postby blizzard » Mon Jan 10, 2022 11:18 pm
In that case the Prime wheels are almost unbeatable unless you can find a set of carbon wheels second handcoffeeallday wrote: ↑Mon Jan 10, 2022 9:51 pmThank you all for your feedback. Was not planning to move to carbon wheels yet and so budget is below 1K. My cycling is mainly for fitness and so some weight is good for the workout . Was just wandering if I could get better ride, etc with improved wheels and tyres over standard issue gear that came with the bike.
Postby coffeeallday » Mon Jan 10, 2022 11:24 pm
Postby blizzard » Tue Jan 11, 2022 7:20 am
Otherwise a shop will fit the wheels and tyres for a fee, you could also combine it with a general service if it's required.
Postby warthog1 » Tue Jan 11, 2022 7:40 am
Do a google search on tubeless bicycle tyres and there will be a heap of info on how to fit them.
You tube should have some stuff.
You need a compressor, or pump with a storage tank, to give a blast of air to seat them.
I have that and have avoided numerous punctures by being tubeless. Love it.
If its' too hard you can use them tubed.
Edit; didn't read Blizzard's post above before posting.
Postby coffeeallday » Tue Jan 11, 2022 9:58 am
@warthog1, I see some comments on Wiggle about stability when windy, something about the wheels not be "aero enabled" - is that something you have experienced? Thanks for your feedback.
Postby warthog1 » Tue Jan 11, 2022 10:23 am
coffeeallday wrote: ↑Tue Jan 11, 2022 9:58 amThank you @warthog1 and @blizzard for your feedback. Since I do not have the necessary tools and the bike is due for a service anyway, that route may be the way to go. Thanks
No.
My 2 roadies are above.
The Cervelo I bought new and has Zipp404s.
Both were heavily marketed as aero.
The Giant I bought as a second hand frame for $450 on ebay.
Used gear off a broken frame to build it up.
It has GP5000TL tubeless tyres on it.
There are fast bunch rides here with some national level riders.
I hang on still, just.
Don't notice any difference in speed between the bikes.
The prime wheels in mine are the same rim as the disc wheels I believe.
They do not blow around in the wind much at all ime. I am not a nervous rider I guess. I have about 15k km on them and am 184cm tall and 76kg.
The Cervelo just hangs on the wall for the most part now.
- Moderator
Postby timbo » Fri Jan 28, 2022 2:04 pm
Postby warthog1 » Fri Jan 28, 2022 2:52 pm
The ones I linked are not expensive and mine are noticeably faster than the aluminium goers they replaced.
I am very happy with them.
He asked this question;
would a wheel upgrade help my riding experience?
It did mine, hence the advice.
- foo on patrol
Postby foo on patrol » Fri Jan 28, 2022 10:26 pm
timbo wrote: ↑Fri Jan 28, 2022 2:04 pmFor somebody who rides 50km, 2 or 3 times per week, I am surprised that people are trying to talk coffeeallday into buying a whole new wheelset. For the distances he travels, granted with uphills, an upgrade to good rolling 28C tyres would be all that he needs.
I hope you don't seriously believe that? Tyres will do Jack chit if the wheels are crap! First rule of thumb is good wheels and then good tyres and all the hype about 28mm tyres is pure bollocks and I'm yet to see anything in real life, to say otherwise. I run 23's & 25's on different sets of wheels and I can't notice any difference in ride quality.
I also see people running stupidly expensive tyres for no other reason than they think it makes them cool and fast, when I can ride with them on my $25 Rubino Pro's and still be as fast and I'm far from being fit. Put a good set of wheels on and that's where you will notice the difference but train/ride more and you will get better gains!
Foo
Goal 6000km
- MattyK
Postby MattyK » Sat Jan 29, 2022 6:42 pm
Postby warthog1 » Sat Jan 29, 2022 7:16 pm
https://www.bicyclerollingresistance.co ... o-iii-2014
Pretty sure they've stopped making em though.
Both good tyres and good wheels can make a difference.
Tyres are cheaper but are a consumable.
Wheels prob give more watt savings but cost more.
I would say get both.
I run the wheels I linked and conti GP5KTL tyres.
Very happy with that combo.
- g-boaf
Postby g-boaf » Sun Jan 30, 2022 6:29 am
Climbing is about gearing and riding more hills more frequently then also losing weight if you are on the heavier side. That’s how you do better at that, no easy wins unfortunately.coffeeallday wrote: ↑Mon Jan 03, 2022 8:43 pmGot my Giant Defy Adv 1 2021 in Jan 2021 after upgrading from a Giant Cross City 0 2019. During the year, the Defy has really helped me improve my ride capabalities which is mainly on the roads and paths - I now try to do a 50km ride 2-3 times weekly. Have been offerred birthday gift options, so looking at what I can do to improve my riding experience. THe 2 main areas seems to be the seat and wheels. While I am reading that seat is very personal, am interested to get some thoughts on the wheels. My bike has the standard Giant PR2 disc tubless with Giant Gavia Fondo 1 tubeless 32c. When the tires need replacement, was looking to move to a 28c but if there were money available for upgrade now, would a wheel upgrade help my riding experience? Where I live, climbs are a normal experience, so any help in climbing would be most useful. Thoughts and experiences appreciated. Thanks.
If you can score some quality lighter wheels at a reasonable price those can help a bit on hills, but they are secondary to training.
- foo on patrol
Postby foo on patrol » Sun Jan 30, 2022 8:24 am
Good/expensive tyre still don't help the initial problem of the crap rolling wheels, they only mask the problem for a bit, where with decent bearings, if sealed ones will help more. There are plenty of cheaper wheels sets that have good rolling bearings and that will be more cost effective over time. There is also no substitute for fitness and Klms on the road.
Foo
Goal 6000km
- cyclotaur
Postby cyclotaur » Sun Jan 30, 2022 4:06 pm
I largely agree with this re: training and weight. But I will say, as an older, average-sized rider with not massive power numbers, that the second part is also true. I picked up some inexpensive 2nd-hand carbon wheels and whacked on my favorite tyres in a 28, and the difference they make to uphill riding in response, power transfer and times is very noticeable, AND the total bike weight came down by 0.5kg.g-boaf wrote: ↑Sun Jan 30, 2022 6:29 amClimbing is about gearing and riding more hills more frequently then also losing weight if you are on the heavier side. That’s how you do better at that, no easy wins unfortunately.
I still use the OEM wheels/tyres for general riding on bike paths and trails, and any gravelly stuff, but if I'm heading to the hills it's the lighter, stiffer wheels and 28s every time.
- Mububban
Postby Mububban » Tue Feb 01, 2022 12:18 pm
My Giant with ~2017 PR2 disc wheels weighed over 2kg for the wheelset! Buying some 1500g Prime carbon wheels from Chain Reaction for under a grand transformed the bike. I'm still skinny and slow, but the bike no longer feels like I'm riding through peanut butter whenever the road points even slightly upwards. Definitely no buyer's remorse from me.coffeeallday wrote: ↑Mon Jan 03, 2022 8:43 pmMy bike has the standard Giant PR2 disc tubless with Giant Gavia Fondo 1 tubeless 32c.
Postby coffeeallday » Tue Feb 08, 2022 4:48 pm
- All times are UTC+11:00
