New bike rubbing brakes
Pink Flamingo
Postby Pink Flamingo » Thu Oct 01, 2020 8:30 pm
Hey folks
Trying to put together a bike and the front disc is rubbing against the brake. It doesn't appear bent. Any idea how to fix?
Also the rear brakes were rubbing so I loosened the wire, except now there is too much movement in the calliper. How can I get this to stay still?
https://vimeo.com/463774284
https://vimeo.com/463774972
10speedsemiracer
Location: Back on the Tools .. when I'm not in the office
Re: New bike rubbing brakes
Postby 10speedsemiracer » Fri Oct 02, 2020 2:02 am
The disc caliper needs realignment, and the video below demonstrates how to do this :
The other brake caliper (linear pull brake) adjustment is covered below :
Take your time, also refer to the owners manual if it came with one, and good luck.
10speedsemiracer
Postby 10speedsemiracer » Fri Oct 09, 2020 12:36 am
Hi P/F, how'd this go ?
Did you get it sorted ?
Pink Flamingo
Postby Pink Flamingo » Fri Oct 09, 2020 10:26 am
Those were the two videos I was using previously. Eventually got the rear brake caliper working. Can't solve the front disc.
ironhanglider
Postby ironhanglider » Fri Oct 09, 2020 10:45 am
Is the front wheel seated properly in the fork?
If it is a Quick Release axle, put the bike on the ground with some weight on the front of the bike undo the QR lever and clamp it up again.
If the rotor is straight and in the right place then it should be a matter of moving the calliper rather than trying to separate the pads.
Cameron
