Aligning disk wheel and chain
22dannyp
Postby 22dannyp » Thu Sep 10, 2020 6:51 am
Hello, I'm setting up a disk wheel on my track bike which has posed the following dilemma:
By playing with the spacers, if the wheel is centred to the frame, the chain is a little out of alignment, and if the chain is aligned perfectly the wheel is slightly off centre?
So what's more important?
ironhanglider
Re: Aligning disk wheel and chain
Postby ironhanglider » Thu Sep 10, 2020 8:54 am
I suppose the question is how much is it off centre and in which direction? It is possible to move the cog relative to the wheel a little with a spacer. Making the cog sit closer to the wheel would be a bit more work.
Cameron
ironhanglider
Postby ironhanglider » Thu Sep 10, 2020 8:55 am
Alternatively, does the chainring need to be moved to fix the chainline from the other end?
Cameron
P!N20
Postby P!N20 » Thu Sep 10, 2020 10:08 am
If a little is only 2 or 3mm, then centre the wheel. The chainline can handle that variance.
foo on patrol
Postby foo on patrol » Thu Sep 10, 2020 11:45 pm
What is the bike, Road or Track? :? Idiot, I just looked at the thread. :lol:
Okay, have you taken the bike for a ride on the Track? What does the chain line sound like, under power and rolling?
Foo
Goal 6000km
22dannyp
Postby 22dannyp » Fri Sep 11, 2020 4:27 pm
Thanks for the help guys, the chain isn't out by very much so I'll get the wheel centred and think about moving the sprocket out if it needs it after a ride.
