Chain wax - yay or nay?
Postby Dylan » Tue Nov 05, 2019 10:03 pm
Thanks,
Dylan.
- Thoglette
Re: Chain wax - yay or nay?
Postby Thoglette » Wed Nov 06, 2019 12:51 am
And you'll find that I'm a fan of old fashioned waxing.Use the search, Luke
- 10speedsemiracer
Postby 10speedsemiracer » Wed Nov 06, 2019 12:58 am
FWIW I'm a dry lube/wet lube person after the factory lube has gone.
- familyguy
Postby familyguy » Wed Nov 06, 2019 8:53 am
Upside: far quieter, far cleaner.
Downside: prep for first time waxing involves REALLY cleaning them (turps bath till it stays clear, metho, let them dry), you have to clean the cassette, jockey wheels and chainrings completely as well, you gotta re-dip them every 300-350km or so as the noise increases.
Going to do another one next week which will mean my 3 main bikes all run wax-only chains.
- Thoglette
Postby Thoglette » Wed Nov 06, 2019 2:10 pm
- cjrich
Postby cjrich » Wed Nov 06, 2019 3:10 pm
- 2015 Cervelo R3
- 2013 Cannondale CAAD 8
- 2019 Marin Rift Zone 3
- bychosis
Postby bychosis » Wed Nov 06, 2019 3:48 pm
I haven’t tried waxing. Sounds like to much hassle, I’ll stick with rock n roll.
- familyguy
Postby familyguy » Wed Nov 06, 2019 3:54 pm
- P!N20
- MattyK
Postby MattyK » Thu Nov 07, 2019 9:35 pm
Chain is lasting a long time, is mess free.
The initial cleaning process and the routine cleanings are easy and really don't require much effort at all, don't let it scare you off.
- RonK
Postby RonK » Thu Nov 07, 2019 10:03 pm
RocknRoll Gold is good, but RocknRoll Holy Cow is even better, no faffing around and no black gunk.
- MichaelB
Postby MichaelB » Fri Nov 08, 2019 10:16 am
There is a local here who is more than knowledgeable re this stuff, Adam Kerin from Zero Friction Cycling.
Whilst he's on about friction savings (which I couldn't really care about), a big aspect of his testing is also about wear & longevity. The link below has some interesting results re the latter points ;
https://zerofrictioncycling.com.au/lubetesting/
Worth having a read of his stuff. Some interesting data there.
Oh, and I currently use Smoove, which is one of the better tested drip waxes, but will soon give waxing a go
- P!N20
- bychosis
Postby bychosis » Fri Nov 08, 2019 1:05 pm
Ditto. Some how I managed to order a second one though so will prob be a few more years after.
- foo on patrol
Postby foo on patrol » Fri Nov 08, 2019 6:04 pm
Foo
Goal 6000km
Postby warthog1 » Fri Nov 08, 2019 7:21 pm
Driveline became noisy very quickly.
Combined with the need to apply a shi ite load of it and at frequent intervals due to the noise, I classified it as uneconomical on the roadie.
- baabaa
Postby baabaa » Fri Nov 08, 2019 7:22 pm
With modern 10/11 speed chains, nope don't bother as they are built to wear by using soft metal so just not worth the effort. That said, from this bloke who knows his stuff, and points out it is pretty hard to find a bad modern chain lube now
http://g-tedproductions.blogspot.com/20 ... s-and.html
Postby Arbuckle23 » Fri Nov 08, 2019 7:57 pm
Way too much stuffing around, changing chains all time, for me.
I just use a lube I get from cycling deal. When I give the bike a good wash the chain gets done as well.
Then, dry off and relube. Wipe excess off. After next ride, wipe off a bit of dripped out excess again.
Check every week or so, or if I get caught in the rain. Wipe off any gunk with a rag and apply a small top up lube.
I got 7000 km out of my last chain and still was not worn out.
I measure with a vernier, not a chain seller , oops, sorry checking tool.
Edited for some spelling typos
- 10speedsemiracer
Postby 10speedsemiracer » Fri Nov 08, 2019 8:34 pm
I actually lol'd, thank you.Arbuckle23 wrote: ↑Fri Nov 08, 2019 7:57 pm.
- OnTrackZeD
Postby OnTrackZeD » Sat Nov 09, 2019 9:28 am
I just change a chain at just over 7k and 0.5% wear but other bike I change at 0.75% which I use a chain checker that the first time I used I compared it with a steel ruler and it was spot on.Arbuckle23 wrote: ↑Fri Nov 08, 2019 7:57 pm
Wax I tried it once and not for me, it put more resistance into the drive train till it warmed up.
- uart
Postby uart » Sat Nov 09, 2019 10:47 am
Nice to see that you got good agreement between both methods. I've never even owned a chain checker, I always just use a steel rule. I measure 12 links along the top of the chain (so that I can put it under mild tension) and typically change at 12.1 inch.OnTrackZeD wrote: ↑Sat Nov 09, 2019 9:28 amI just change a chain at just over 7k and 0.5% wear but other bike I change at 0.75% which I use a chain checker that the first time I used I compared it with a steel ruler and it was spot on.
- Duck!
Postby Duck! » Wed Nov 13, 2019 2:13 pm
Fixed for you. Chain links are 1/2" pitch.
- Duck!
Postby Duck! » Wed Nov 13, 2019 2:19 pm
No, they're made of the same stuff, but being narrower the contact load is concentrated on smaller contact areas, increasing the point load.
- baabaa
Postby baabaa » Wed Nov 13, 2019 6:11 pm
Oh that's good to know. So where I can get the 10 or 11 speed version made with this metal?
Name your price, am a buyer as these do last for many, many kms and even years.
- 10speedsemiracer
Postby 10speedsemiracer » Wed Nov 13, 2019 6:34 pm
