I thought it had died out. I guess still some mainframe COBOL programs around ... Is that what you are working in?twizzle wrote:I STILL write in COBOL from time to time.
Postby Aushiker » Sun Jan 24, 2010 2:22 pm
Postby twizzle » Sun Jan 24, 2010 3:17 pm
Postby clack3rz » Mon Jan 25, 2010 9:17 am
So *any* manufacturer wheel as long as there is a std spoke count and even L-R?Alex Simmons/RST wrote: However, you'll need to choose a rim that uses standard spoke holes and an even L-R spoke count.
Postby twizzle » Mon Jan 25, 2010 10:00 am
You need to check the hub first, they come in limited versions, ie. 'Comp' is only available in 32 spoke, some of the others are available in 24 spoke.clack3rz wrote:So *any* manufacturer wheel as long as there is a std spoke count and even L-R?Alex Simmons/RST wrote: However, you'll need to choose a rim that uses standard spoke holes and an even L-R spoke count.
Postby clack3rz » Mon Jan 25, 2010 10:20 am
Thanks Twizzle.twizzle wrote:You need to check the hub first, they come in limited versions, ie. 'Comp' is only available in 32 spoke, some of the others are available in 24 spoke.clack3rz wrote:So *any* manufacturer wheel as long as there is a std spoke count and even L-R?Alex Simmons/RST wrote: However, you'll need to choose a rim that uses standard spoke holes and an even L-R spoke count.
Postby twizzle » Mon Jan 25, 2010 10:39 am
Postby clack3rz » Mon Jan 25, 2010 11:05 am
Postby Aushiker » Mon Jan 25, 2010 1:00 pm
Hiclack3rz wrote:EDIT: Apologies for the hijacked thread.....
Postby clack3rz » Mon Jan 25, 2010 1:08 pm
Thanks - I just dislike hijacking OP's threads......Aushiker wrote:Hiclack3rz wrote:EDIT: Apologies for the hijacked thread.....
I don't think you have anything to apologise for. I found your question and the information that came from them interesting.
Postby Aussiebullet » Tue Jan 26, 2010 9:08 am
Postby clack3rz » Wed Jan 27, 2010 7:16 am
Hi - Will check out the forum - thanks.Aussiebullet wrote: If you head over to the "weight weenies" web site in the road section there is a "sticky at the the top of the page called the wheelbuilding thread, it is a gold mine for newb wheelbuilders and experianced builders for that matter,
it has loads of info on building pt wheels from arguably the "best" wheel builders in the world if there is such a thing lol.
l usually buy rim, spokes, nipples and hub of choice, grease nipples and threads then lace them up and get any LBS to tension/true them up for ~$30. I've laced up a pt wheel myself (24h niobium 30 rim) they are no diff to any other hub just be shure to do at least 2 cross on the non drive side,
Mine is still going strong with 30'000 + kms on it!
Its easy and cheap, the cost can blow out a bit though if you get LBS to order rims, spokes etc and get them to lace it up and build it from scratch.
Have fun
Postby brentono » Wed Jan 27, 2010 10:17 am
clack3rz wrote:a good training wheel (a little on the heavier side)
Postby twizzle » Thu Apr 29, 2010 1:28 pm
Postby donncha » Thu Apr 29, 2010 4:01 pm
Postby JV911 » Thu Apr 29, 2010 4:17 pm
thanks for the heads-updonncha wrote:Also, competitivecyclist.com in the US are doing a Comp built into a DT wheel for US$650 which might be worth checking out.
Postby donncha » Thu Apr 29, 2010 4:37 pm
Postby toolonglegs » Thu Apr 29, 2010 6:49 pm
Postby donncha » Thu Apr 29, 2010 6:57 pm
Postby JV911 » Fri Apr 30, 2010 9:02 am
good idea - prices are a fraction more than c r c and wiggle (free postage) but if they can better their prices it would be good. They have Quarqs too ...mmm Quarqtoolonglegs wrote:They always beat their web price by a fair bit.
Postby ft_critical » Fri Apr 30, 2010 12:02 pm
Hi Alex, (anyone else too)Alex Simmons/RST wrote:But if you want to quantify your performance level, and work on how to improve it, then it is an excellent tool for the job.
Postby JV911 » Fri Apr 30, 2010 12:16 pm
i'm with youft_critical wrote:This is probably ignorance on how a power meter is employed during training
Postby twizzle » Fri Apr 30, 2010 1:22 pm
Wire from the head unit to a receiver mounted on a chain or seat stay on the non-drive side near the hub.JV911 wrote:thanks for the heads-updonncha wrote:Also, competitivecyclist.com in the US are doing a Comp built into a DT wheel for US$650 which might be worth checking out.
wiggle and c r c have them too (mavic open pros) but out of stock...was looking at the "elite" though as i wanted ANT + and didnt really want wired (i'm assuming "wired" means there is a wire going from the hub to the head unit?)
Postby twizzle » Fri Apr 30, 2010 1:36 pm
And would your speed difference be due to more power, better tyres, better position on the bike, different cadence, wind...?ft_critical wrote: What greater benefit would I get from a power meter over the above tests (which in my humble opinion) are effectively measuring power? This is probably ignorance on how a power meter is employed during training.
Sorry you have to exlain the same things over and over.
Postby Alex Simmons/RST » Fri Apr 30, 2010 2:38 pm
Your thoughts about using a hill climb are on the right track.ft_critical wrote:What greater benefit would I get from a power meter over the above tests (which in my humble opinion) are effectively measuring power? This is probably ignorance on how a power meter is employed during training.
