Hub Dynamos in Australia
Re: Hub Dynamos in Australia
Postby Jubas » Wed Mar 20, 2019 8:57 am
And, I'm assuming there's no beam cut-off ala the german lights?
- Mugglechops
Postby Mugglechops » Wed Mar 20, 2019 9:16 am
Wired direct from hub to light on this one.Jubas wrote:Interesting - do you have to use the wiring loom from K-lite with the switch/battery pack? Or can you just go direct from hub to light?
No cutoff like the german lights, but you can actually see where you are going with this one
Postby Luke Skystalker » Fri Dec 27, 2019 7:41 pm
I’m a n00b & am surprised how expensive a dynamo setup seems to be. I guess they’re not as common as I thought!
Having to plug in lights to charge every day doesn’t appeal to me. But at what cost? Wondering what the cutoff is to have a good dynamo setup.
Thanks for your insight.
Postby march83 » Fri Dec 27, 2019 7:51 pm
I quite like the Busch and Muller iqx headlights. One of those and a tail light and you're up for another $120.
Short term you can do something better with battery powered leds for the same money, but long term, being able to just roll out the door without working about lighting, never getting caught out after dark, etc wins IMO
- Thoglette
Postby Thoglette » Sat Dec 28, 2019 11:27 am
You can get a "bottle" genertor which runs on the sidewall of the tyre for much less but the vast majority of these are less efficient than a hub and require strong sidewalls. There's the occasional tread-running generator but these'd be an ebay find
- Bunged Knee
Postby Bunged Knee » Sat Dec 28, 2019 1:58 pm
It runs at 15-20w better than the 3w bottle dynamo. With basic at $US250 to $US300 but with extra $US50 to $US100 after promo possibly after March, ($AU358 to $AU430) for the ultimate bundle with no info of postage cost to ship in early March 2020.
- foo on patrol
Postby foo on patrol » Sat Dec 28, 2019 2:10 pm
Foo
Goal 6000km
- MichaelB
Postby MichaelB » Sat Dec 28, 2019 2:24 pm
- Aushiker
Postby Aushiker » Sat Dec 28, 2019 2:26 pm
When you say the don't work when you stop, I assume you are referring to at the traffic lights, stop signs etc. If that is correct then my Busch & Mueller lights all have a stand-by feature which means the lights stay on for four minutes. More than enough time at traffic lights etc.foo on patrol wrote: ↑Sat Dec 28, 2019 2:10 pmThe dynamo lights don't work when you stop, do they? So that in itself is a negative for me.
Foo
Aushiker.com
- Aushiker
Postby Aushiker » Sat Dec 28, 2019 2:28 pm
Haven't heard of this before. Looks interesting from a quick look at the website. Always good to see other options too.Bunged Knee wrote: ↑Sat Dec 28, 2019 1:58 pmHad anyone heard of the " dynamo of the future? " from https://www.pedalcell.com/cadencex
Thanks for sharing.
Aushiker.com
Postby Baalzamon » Sat Dec 28, 2019 7:22 pm
Oring needs replacing every 2000 miles. Rules it out for serious touring.Aushiker wrote: ↑Sat Dec 28, 2019 2:28 pmHaven't heard of this before. Looks interesting from a quick look at the website. Always good to see other options too.Bunged Knee wrote: ↑Sat Dec 28, 2019 1:58 pmHad anyone heard of the " dynamo of the future? " from https://www.pedalcell.com/cadencex
Thanks for sharing.
- foo on patrol
Postby foo on patrol » Sat Dec 28, 2019 7:34 pm
Well there ya go but I'll still take my rechargeable ones over a dynamo.
Foo
Goal 6000km
- rifraf
Postby rifraf » Mon Dec 30, 2019 8:22 pm
Why not have a re-chargeable that recharges via a dynamo.foo on patrol wrote: ↑Sat Dec 28, 2019 7:34 pmWell there ya go but I'll still take my rechargeable ones over a dynamo.
Foo
- foo on patrol
Postby foo on patrol » Tue Dec 31, 2019 5:33 am
Because I get 4-7hrs out of my 50x30x5mm battery.rifraf wrote: ↑Mon Dec 30, 2019 8:22 pmWhy not have a re-chargeable that recharges via a dynamo.foo on patrol wrote: ↑Sat Dec 28, 2019 7:34 pmWell there ya go but I'll still take my rechargeable ones over a dynamo.
Foo
Foo
Goal 6000km
- antigee
- Location: just off the Yarra Trail but not lurking in the bushes
Postby antigee » Wed Jan 01, 2020 2:46 pm
not seen an independent review though...I've been looking at building up a dynamo wheelset for a long ride to charge stuff as well as if run out of daylight and if you look at the data from the top performing (German) brands then they get nowhere near the numbers being talked about by this co'...impressive if the numbers are correct...their graphs would suggest that their product will charge stuff even down at typical offroad touring speeds...presented as solid comparison data rather than a headline number so hopefully something in it...hope they can come up with a hub versionAushiker wrote: ↑Sat Dec 28, 2019 2:28 pmHaven't heard of this before. Looks interesting from a quick look at the website. Always good to see other options too.Bunged Knee wrote: ↑Sat Dec 28, 2019 1:58 pmHad anyone heard of the " dynamo of the future? " from https://www.pedalcell.com/cadencex
Thanks for sharing.
- MichaelB
Postby MichaelB » Thu Apr 16, 2020 11:19 am
Been a dynamo user for quite a while now and have the E3 Triple SuperNova as a front light which has been working fine (and a small rear light as well.
One thing I've noticed in the last few weeks is that the standlight capacity is now non-existant.
I'm hesitant to open it up and it aint cheap to replace ?
Any suggestions ?
Edit : Exposure Revo seems to be a good alternative, but doesn't seem to have a mount that allows it to fit to a fork crown (using the hole normally associated with the fender/rim brakes). I've seen the stem mount, but can't use that, as that's where I mount the Wahoo Bolt.
Postby LateStarter » Thu Apr 16, 2020 11:29 am
2008 Cannondale Touring, 2013 Vivente World Randonneur, 2015 Lynskey Sportive (Audax)
- MichaelB
Postby MichaelB » Thu Apr 16, 2020 11:37 am
I have a flashing rear and will probably look at a flashing front (both are good as backups anyway), but typically when I stop, it's at traffic lights.LateStarter wrote: ↑Thu Apr 16, 2020 11:29 amWith motorists apparently unable to tell the difference between a bright constant rear light and a road side reflector the best practice these days seems to be having both Dynamo constant and flashing rear (or two) so stand light might be redundant?
Just curious for ideas of cause, and options/advice if it dies on me.
- queequeg
Postby queequeg » Thu Apr 16, 2020 12:11 pm
I have a SupaNova E3 Pro 2 & E3 Taillight, my first foray into Dynamo Lighting. Unfortunately I find it too restrictive for what I use it for, which is Audax in pitch black at high speed. I am therefore looking to redo the light rig and move to the k-Lite dyno lights, which are actually Australian. Most of the Ultra Endurance riders use the K-Lite lights and they are some of the brightest lights you can get. I have also heard good things about the Sinewave beacon light. It uses a cache battery so the stand light runs for ages.MichaelB wrote: ↑Thu Apr 16, 2020 11:37 amI have a flashing rear and will probably look at a flashing front (both are good as backups anyway), but typically when I stop, it's at traffic lights.LateStarter wrote: ↑Thu Apr 16, 2020 11:29 amWith motorists apparently unable to tell the difference between a bright constant rear light and a road side reflector the best practice these days seems to be having both Dynamo constant and flashing rear (or two) so stand light might be redundant?
I’ve got my new fork sitting in a Sydney TNT depot somewhere waiting for it to get through customs. Massive delays due to covid. The new fork has internal routing for the dyno wiring as well as extra bottle cage mounts. I will most likely take my Supanova light and put it on my commuter bike, which is really only ridden on the road. Just have to source a 36H Dyno Hub and matching rim so I can build a new front wheel without pulling my non-dyno one apart.
Postby Trevtassie » Thu Apr 16, 2020 12:36 pm
- MichaelB
Postby MichaelB » Thu Apr 16, 2020 2:00 pm
I had something similar when I was a kid.Trevtassie wrote: ↑Thu Apr 16, 2020 12:36 pmhttps://www.pedalcell.com/cadencex Still trying to figure out how a wet O-ring can turn a generator that puts out 15-20W. Plus I do like how they use the lowest possible output for a hub dynamo...
The bottle dyno was useless back then, and prob not much better now.
Postby hamishm » Thu Apr 16, 2020 2:13 pm
I also had the E3 Pro 2 and found it too dim for pitch black descending. I'm no longer doing rides that need dynamo lighting, but the next light I would try is the IQ-X, which gets good reviews from people who I trust on such things.
I previously had a Luxos U which was good until the plastic case eventually fell apart.
- MichaelB
Postby MichaelB » Thu Apr 16, 2020 2:24 pm
Had a look at the K-Lite page, and whilst I'd be happy to shop there and get their Pro V2 (on sale), there are two things that don't suit my application - the standby battery (too big and bulky for normal road riding), and the lack of mounting options.queequeg wrote: ↑Thu Apr 16, 2020 12:11 pm.... I am therefore looking to redo the light rig and move to the k-Lite dyno lights, which are actually Australian. Most of the Ultra Endurance riders use the K-Lite lights and they are some of the brightest lights you can get. I have also heard good things about the Sinewave beacon light. It uses a cache battery so the stand light runs for ages.
And the Ultra V2 (out of stock) is just overkill.
There doesn't appear to be many dyno lights similar in style/mounting to the E3's (and don't look like a bug eyed meerkat seeking attention).
- RonK
Postby RonK » Thu Apr 16, 2020 2:52 pm
However it is complicated because the Revo does not have a switch, and also if you want to charge a powerbank you will also need a charger and a two-way switch.
Here I'm using a K-Lite switch and Sinewave Revolution charger mounted on the underside.
And a warning about the Revo - the sockets are identical - DO NOT interchange the input and the output, or you'll be sending it back to Exposure in the UK for repair.
Although it worked quite well, eventually I grew weary of this clutter and bought a Sinewave Beacon, which I mounted on a K-Edge Wahoo/GoPro combination mount, using a KevinB GoPro to Dynamo light adapter. And kept it simple with a AAA battery-powered flasher for the rear.
And a final comment - neither the Revo or the Beacon are particularly bright, adequate for riding on the road at moderate pace but not good for offroad or high speed riding. If you need offroad capability then bite the bullet and buy the K-Lite.
- baabaa
Postby baabaa » Thu Apr 16, 2020 2:57 pm
https://www.bumm.de/en/products/mehr/produkt/470lh.html?
Mounted a B & M Lumotec IQ Cyo T ( whatever that means ) up high with one of these in Sth America to avoid the salted roads, mud, rubbish and grime. Did not have muddies on the bike. Seems to worked as required as the light is still working well. Also, being high gave a bit more width to the beam, maybe?
Have gone back to a fork mount now as I lug stuff on the bars. The light itself is good as a standing light but apart from other commuters stopped at lights I have little to compare it with.
- All times are UTC+11:00
