Hub Dynamos in Australia
Re: Hub Dynamos in Australia
Postby wqlava1 » Thu May 11, 2017 2:41 pm
Postby hamishm » Thu May 11, 2017 2:55 pm
This one? https://www.sinewavecycles.com/collecti ... les-beaconwqlava1 wrote:I think Revolution just released an integrated light/USB charger. Not cheap though.
Looks ok, need to add an external battery, but you weren't kidding about the price.
Looks like I could get a new Luxos U from Starbike for about $200 Aussie shipped.
Postby wqlava1 » Thu May 11, 2017 3:02 pm
Postby hamishm » Thu May 11, 2017 4:18 pm
Some audax friends suggested going separate light/charger so I can have the best of each. Most of the separate charger devices seem quite bulky or not waterproof (like the Sinewave Revolution). The UK-made Igaro charger looks interesting in this regard - goes in-line in the cables, and has waterproof connectors.
- find_bruce
- Moderator
Postby find_bruce » Thu May 11, 2017 5:49 pm
That's a bugger about your luxos.hamishm wrote:I spoke too soon about liking the Luxos U. Suddenly it has quick release.
What's next? Another one ($290 locally, ouch), or something else? K-Lite? Can I fix it?
I like
- compact for combination light, battery, charging (charging essential for my Edge 1000 on long days)
Less impressive
- Cable insulation coming away at the remote switch
- Beam not super impressive
- Would like flashing mode if possible
Didn't like
- Weatherproofing
- That it broke after a couple of years on the road.
I wouldn't get your hopes up about flashing - flashing front & back is simple to achieve (just back is waaay harder) - in fact one of the things you desing into the lights is to stop flashing at low speed, BUT no one makes em.
You have a tough choice looking at dynamo lights ATM as the beam quality is lacking. The Philips saferide 60 used to be the best but is no longer made. Spanninga have taken over and assuming that they have kept the same beam, the Axendo 60 would be worth looking at. Availability seems to be a problem as I have yet to find a price to ship to Australia.
The k-light & sinewave lights (& my own diy lights) are "symetrical" beams - aka standard, round, conical, unshaped. Serviceable but not as effective for road use.
Postby hamishm » Thu May 11, 2017 6:45 pm
I've heard good things aboutfind_bruce wrote:You have a tough choice looking at dynamo lights ATM as the beam quality is lacking.
- Schmidt Edelux II
- SuperNova E3 Triple 2 http://supernova-lights.com/en/supernova-e3-triple-2 ("Not German Road Legal")
- B&M Cyo
Any thoughts on those?
Postby wqlava1 » Thu May 11, 2017 7:56 pm
The IQ-X looks pretty reasonable for a cut off beam, but the Sinewave and K-lite are more robust and heaps brighter ( and exy in proportion unfortunately).
- rifraf
Postby rifraf » Thu May 11, 2017 8:39 pm
hamishm wrote:I've heard good things aboutfind_bruce wrote:You have a tough choice looking at dynamo lights ATM as the beam quality is lacking.
- Schmidt Edelux II
- B&M Cyo
The Edelux suits my taste in aesthetic.
I'm still happy with my Mk 1 version, which isn't to say that the 11 isn't better, merely that I've not felt the need to upgrade.
Its possible when I run out of other toys I want for my bike I'll reconsider but currently I'm not even thinking about it
I'm a little underwhelmed with B&M lights in general due to reading of issues with a range of lights.
Saying that, I've read of plenty of satisfied customers of theirs too, just to further confuse the issue.
Their Luxos I think was one I seriously considered but read of too many failures in the end to wish to put my hand in my pocket.
The specs looked good on paper mind you and I believe their combining a headlight with usb charging was inspired.
Please think carefully before buying a E3 Triple.
Its designed as an off road and is not suitable as an on tarmac light due to blinding other road users.
Bicycle riders get enough bad press already, without unsuitable headlights being added to motorists pet hates like red light transgressors.
In my opinion it further creates a them and us mantra and gives ammunition to the anti-cyclist brigade, most of whom arent even sure why they hate cyclists.
Just my thoughts as requested.
Your big enough to make up your own mind what works best for you.
- MichaelB
Postby MichaelB » Fri May 12, 2017 8:36 am
I love the E3 Triple.
- baabaa
Postby baabaa » Fri May 12, 2017 9:38 am
- rifraf
Postby rifraf » Fri May 12, 2017 12:45 pm
Everyone has to make up their own mind on headlight choice and use what they determine what works best for themselves.MichaelB wrote:I use an E3 Triple, and it's well aimed. Any good light can blind oncoming traffic if poorly positioned. Worse if it's a poorly positioned blinky.
I've not seen the E3 in use in the flesh, but Supernova's site last I was there talked up the use of of the E3 Triple as suitable for off road use only, which is what I based my own choice on.
When riding or driving, others poorly aimed headlights blinding me is a fierce source of frustration to me which I try to temper with the knowledge that most road users wouldn't consider how their lights might affect others, generally out of ignorance and not necessarily out of malice.
This seems as true on the road as on the cycle path.
I've given up attempting to palatably inform other road users whilst riding.
No suggestion you personally have ill aimed lighting MichaelB, merely pointing out the E3 Triple is marketed as an off road light.
Given that bicycles frustrating motor vehicles can engender dangerous levels of road rage in innocuous situations, my personal choice was an easy one.
- MichaelB
Postby MichaelB » Fri May 12, 2017 12:58 pm
Waiting for spokes to rebuild my dynamo wheel, and I am REALLY missing the vision I have now that darkness is descending earlier.
- RonK
Postby RonK » Fri May 12, 2017 1:54 pm
This is of course a reference for use in Germany, in accordance with German law.rifraf wrote:I've not seen the E3 in use in the flesh, but Supernova's site last I was there talked up the use of of the E3 Triple as suitable for off road use only, which is what I based my own choice on.
You need to keep in mind that apart from German-sourced lights, the majority of lights sold in the rest of the world do not have shaped beams.
And in fact most widely available battery-powered lights use symmetrical beams and many are far, far brighter than dynamo lights such as the E3 Triple or the Exposure Revo that I'm using.
- rifraf
Postby rifraf » Fri May 12, 2017 8:59 pm
Its seems obvious to me that Australia is behind the ball when it comes to legislation regarding sensible lighting for "all" road users.RonK wrote:This is of course a reference for use in Germany, in accordance with German law.rifraf wrote:I've not seen the E3 in use in the flesh, but Supernova's site last I was there talked up the use of of the E3 Triple as suitable for off road use only, which is what I based my own choice on.
Thats merely an observation and not an indictment.
Having some awareness of needlessly offering free suntans and cataracts to other road users and errant wildlife suggests a whimsy that unnecessarily invites a potential conflict with already rage affected road users.
Much as I'd love a set of aircraft landing lights powered by my dynamo, with an ability to singe the hair of kangaroos in my path, I make the conscious choice to ride the path of discretion as opposed to valour.
I'm in no way attempting to tell people what they should have on their bikes regarding lighting or anything else.
By the same token, anyone who blinds me with their lights gets a serve.
A perhaps topical point of trivia is I believe the flashing light on my fly12 is bright enough to be dangerous if aimed aggressively
Postby hamishm » Sun May 14, 2017 3:41 pm
The Luxos U supposedly has that too, and I've never understood how it's meant to work.baabaa wrote:I have theBusch & Müller LED Lumotec IQ Cyo T, with.... "Daytime Running Lights (Licht 24)", as they call it.
One site I read said the yellow status LED means daylight mode, blue means full. But that's not what the instructions say (or how I understand it): yellow is normal operation from the dynamo, blue is floodlight where it supplements the dynamo with the battery power, which obviously only lasts until the battery is flat.
So that only leaves yellowing being ON and some sort of daylight sensor to control which mode.
Postby hamishm » Sun May 14, 2017 5:06 pm
I only ever felt the Luxos U output was lacking when descending in the pitch black, which I don't do much of. The floodlight mode (battery-backed) should help. A brighter light with a choice of less light when I don't need it would be fine - I don't see any mention of different output levels on the SuperNovas though.
- baabaa
Postby baabaa » Sun May 14, 2017 5:42 pm
http://www.peterwhitecycles.com/b&m-hl.php
First I'll describe the "T" version. In Senso mode riding in daylight, the Daytime Running Lights are at full brightness. At dusk, the headlight will automatically switch over to nighttime mode and the Daytime LEDs will dim down so the road can be fully illuminated by the main LED which runs at full brightness. Or you may switch it off entirely.
I tend towards simple things so avoided the Luxos as a few too many bits to go wrong for me. After I had my B&M for a few months I had a bloke stay at my place for a few days and was running a Luxos with the USB recharge option with the handlebar mounted button. This caused him grief from the start of his ride. Ok he was four sixths of a round the world trip but was angst he didn't need and was going to get a Sinewave Reactor USB recharge thing once he made it down to Melbourne or Christchurch and had a bit of time.
He found it fiddly and was always breaking so was re-wired and sitting on his bar with tape and zip ties. We did the same sort or repairs when he was here. Was not happy camping out in Kyrgyzstan and not knowing if he was going to have working lights one day or no recharging the next.
I think the auto works well but if you need to change between high and low best mount another flood type light so you can reach it and not rely on a switch at the end of another wire. Besides oz bush rats just love to do the midnight feast on these sort of things (and salty leather saddles, gum brake hoods, tasty leather bar tape.....)
Postby 00tones00 » Sat May 20, 2017 2:21 am
I run a Luxos U and find it pretty good. It has 2 sets of lights inside. The first (Licht 24) are 2 bright LEDs that shine more upward and only operate automatically during sunlight. There is another bulb that activates during low light as well with a more "car headlight" style beam. This one also adjusts its beam as well during very low speed so that it highlights the ground very close to you. The additional button (with Blue colour) triggers both lights at once and is more dependent on the cache battery. The USB charging operates at trickle charge with the light on (~0.1 amp I think) but can go up to 1 amp (?) with the light turned off. The only issue I had was when I did a lot of very low speed riding of 5-10km/h (I was riding next to someone who was walking for a long time) and doing twice daily shopping trips up steep hills in thongs without going out for a faster ride in over a week. This really drained the cache battery. The impact of this is that if you want to disable the day light to better charge the USB with the cache battery drained, the system would reset every time you stop at traffic lights and then turns the light on with little or no USB charging. I think the same thing can happen if you leave a garmin connected to it charging overnight. Once I did a commute to work (12km (AT) 20km/h) it was all better.hamishm wrote:The Luxos U supposedly has that too, and I've never understood how it's meant to work.baabaa wrote:I have theBusch & Müller LED Lumotec IQ Cyo T, with.... "Daytime Running Lights (Licht 24)", as they call it.
As a commuter light it works really well by prioritizing lights over USB charging. You just need to be mindful of the USB charging limitations when touring although if you can keep an average speed above ~16km/h then its fine. There are no issues on a faster audax style ride at all.
Postby hamishm » Sun May 21, 2017 5:31 pm
So you just switch the light on (yellow light at the back) and it will do the right thing at all times, daylight / low speed / high speed?00tones00 wrote:I run a Luxos U and find it pretty good. It has 2 sets of lights inside. The first (Licht 24) are 2 bright LEDs that shine more upward and only operate automatically during sunlight. There is another bulb that activates during low light as well with a more "car headlight" style beam.hamishm wrote:The Luxos U supposedly has that too, and I've never understood how it's meant to work.baabaa wrote:I have theBusch & Müller LED Lumotec IQ Cyo T, with.... "Daytime Running Lights (Licht 24)", as they call it.
Good to know I'm not missing anything then. Thanks.
I've glued mine back together and it survived one ride of 75km so far. I'll think about a replacement soon.
Postby 00tones00 » Sun May 21, 2017 5:54 pm
Yes I've found it plug and play. I also run a rear light off it as well which I think runs all the time even if you turn off the main light for full USB charging. I haven't fully investigated it's operation under all conditions yet so not 100% sure.hamishm wrote: So you just switch the light on (yellow light at the back) and it will do the right thing at all times, daylight / low speed / high speed.
Postby hamishm » Mon May 29, 2017 3:48 pm
Only got about 200km on it before it broke again.hamishm wrote:I've glued mine back together and it survived one ride of 75km so far. I'll think about a replacement soon.
Now I'm thinking I don't need charging for a little while (I have the Garmin battery pack too), so I could just get a light. Maybe the Triple... or maybe something cheaper.
Postby hamishm » Tue May 30, 2017 6:55 pm
- E3 Pro 2
- IQ-X
- Edelux II
Thoughts? The first two come with mounts which seems easiest, the last seems confusing. IQ-X is cheapest I think. I read a review which said the IQ-X beam is too narrow though.
- RonK
Postby RonK » Tue May 30, 2017 9:24 pm
- find_bruce
- Moderator
Postby find_bruce » Tue May 30, 2017 9:38 pm
Postby hamishm » Tue May 30, 2017 11:20 pm
Thanks, I found a good price on it from SJS cycles so I ordered.RonK wrote:I've had an E3 Pro. It was a very high quality item and I'd be happy to have another.
But now I'm not sure if I need the separate fork mount (http://supernova-lights.com/en/supernova-e3-pro-2 shown near the bottom) to mount it behind my road rim brake or not?!
- All times are UTC+11:00
