650b: hype?
- Bendo
Re: 650b: hype?
Postby Bendo » Sun Jan 29, 2017 3:20 pm
Most guys on group rides wouldn't even know what they were looking at. The narrow-minded !! BAN ME NOW FOR SWEARING !! I've encountered from most roadies about my bikes (vintage steel, non-700c wheels, mudguards) means I just can't bothered anymore. Not surprised you kept up with them and great retort too! b
Re: 650b: hype?
Postby robHflyte » Sun Jan 29, 2017 6:34 pm
But I am thinking of organising an Audax no drop ride soon, one to get Latestarter over his first 300 and also as a way of getting those that may be a little apprehensive of riding 100 or more feeling confident that they can do it. Average moving speed will be in the low 20s, very similar to a BUAF I think.
My Kumo frame is 61cm, I should go measure the rake, it certainly works well with heavily loaded and unloaded front bag so whatever it is, it is fine.
- Thoglette
Re: 650b: hype?
Postby Thoglette » Sun Jan 29, 2017 6:54 pm
630 + 2 x 32mm = 694 (almost 700C). To match that you need 55mm tyres on your 650b (Iso 584).Bendo wrote:g But thinking about it now, it has 27" (ISO630) rims, so there we might have yet another reason to go 650b! Less chance of overlap that bigger wheel sizes maybe?
The challenge is brakes - you need 23mm more reach in the same frame/forks
- Bendo
Re: 650b: hype?
Postby Bendo » Sun Jan 29, 2017 9:53 pm
Sorry I meant on separate bikes designed for their respective wheel sizes, not just putting smaller wheels in a bigger frame. bThoglette wrote:630 + 2 x 32mm = 694 (almost 700C). To match that you need 55mm tyres on your 650b (Iso 584).Bendo wrote:g But thinking about it now, it has 27" (ISO630) rims, so there we might have yet another reason to go 650b! Less chance of overlap that bigger wheel sizes maybe?
Re: 650b: hype?
Postby Virgil Walker » Thu Aug 03, 2017 6:26 am
Haven't used 650b. Have used Compass Bon Jon Pass 35 mm Extralight and Stampede Pass 32 mm Extralight (both are 700c) for some time now on road, gravel, and Audax. Best tyres I've used. I prefer the BJPs: I've done my fastest 200s on them, they're excellent on gravel and in wet. Long lasting and only get punctures after about 4-5000 km IME. I get around 7000 km out of the SP XLs. They're expensive, but better than anything else I've used.
Re: 650b: hype?
Postby robHflyte » Thu Aug 03, 2017 9:12 am
Virgil Walker wrote:Just a follow up:
- darkelf921
Re: 650b: hype?
Postby darkelf921 » Thu Aug 03, 2017 2:12 pm
Re: 650b: hype?
Postby owly » Sun Aug 06, 2017 8:09 pm
Do you like the 35's best, mainly due to the extra width/contact over the 32's ?Virgil Walker wrote:Just a follow up:
Been running EL 32 on and off for the last year. Have to take it easy when downhilling over loose gravel w/hardpack underneath. Even more-so on off camber downhills, so the tire doesn't slide away.
- singlespeedscott
Re: 650b: hype?
Postby singlespeedscott » Mon Aug 07, 2017 7:03 am
- cameronp
Re: 650b: hype?
Postby cameronp » Mon Aug 07, 2017 12:51 pm
Been looking at building a gravel bike around the new Kinesis Tripster AT frame and going 650b is a definite possibility, but it's still a bit of a gamble. At least in 700c I know there are several tyres I get along with.
Re: 650b: hype?
Postby Virgil Walker » Mon Aug 07, 2017 7:00 pm
Yes. Better cornering on both gravel and asphalt. And I can discern no difference in aerodynamic resistance, though logically there must be greater resistance.
BTW I've never had any problems with sidewall damage on either Stampede Pass XL or BJP XL except once when I managed to drop a front tyre into an unexpected and unavoidable crack in the bitumen in the direction of travel on a bike path. It just scraped one cord of the carcass. IMO, any tyre would have suffered similarly. I still use the tyre.
I run the SP XL tyres at around 50-55 psi, tho I don't check them every ride and they sometimes go as low as 40 psi without much discernible difference in ride quality. Or not enough to worry me. I weigh 82 kg and often carry extra stuff for audax
At the recent LEL there were many bikes on Compass tyres (32-38 mm in 700c; 38-48 mm in 650b; and at least one, I think, on 54 mm 559).
Re: 650b: hype?
Postby Virgil Walker » Mon Aug 07, 2017 7:21 pm
FWIW What has caused me to DNF in audax events when it happened, has not been slower average speeds, but injury and/or bike damage due to falls, or adverse reactions to bad, inappropriate, or non-existent food. All of these are more to do with combinations of inexperience, lnsufficient planning or preparation, and fatigue. Beyond a certain level, the wheels and tyres probably don't make much difference. But wider more comfortable tyres might provide some benefits in comfort and stability and, with 650b and 559 wheels, slightly stronger wheels.
- hartleymartin
Re: 650b: hype?
Postby hartleymartin » Tue Oct 24, 2017 2:38 am
- brasstinman
Re: 650b: hype?
Postby brasstinman » Mon Jan 29, 2018 10:51 am
Re: 650b: hype?
Postby dubudu » Tue Nov 27, 2018 6:21 pm
a slightly off topic question, has anyone tried the compass 26 x 2.3" rat trap pass. Thinking of building up an old mountain bike as a relaxed riding gravel bike. I have 650b 38mm pari-motos in my road bike and love them. Thinking the RTP should be really plush.
Joe
- singlespeedscott
Re: 650b: hype?
Postby singlespeedscott » Wed Nov 28, 2018 11:51 am
Obviously single track is not their modus operandi but on hard pack they are acceptable, anything lose needs to be ridden with caution.
For the forestry roads and rail trails, surface varying between sand through to fist sized rolled aggregate, they are perfect. They float through deep, dry sand and they absolutely fly on fire roads, seriously my mates on “gravel bikes” with 45mm tyres can’t keep up.
I have also used them on my commute to work and find they roll no slower than my 32mm stampede pass tyres. I still manage to average around 28kmhr for my 30km commute.
They are also an absolute ball on bitumen descents. They have that much grip that you can corner like your riding a moto.
If possible I would suggest you set them up tubeless to get the most out of them. It’s not that I’ve have found them puncture prone it’s just that I have had few pinch flats when running tubes with them. These tyres roll so fast off road that you really can smack into protruding rocks pretty hard.
Re: 650b: hype?
Postby dubudu » Wed Nov 28, 2018 1:17 pm
- singlespeedscott
Re: 650b: hype?
Postby singlespeedscott » Wed Nov 28, 2018 5:32 pm
I don’t have anything suitable atm sorry. Keep looking, something will turn up. The style of frame you want is an early to mid 90’s hardtail. The geometry, other than the higher bottom bracket is nearly identical a modern “ gravel” bike. There is a guy from the US selling some NOS Cr Mo mongoose frames on eBay that should work.
Don’t limit yourself with a rigid fork either. I run my old bike with a Marzocchi Z2 atom bomb fork. A decent suspension fork with fat tyres will plow through anything whilst your mates on their skinny 45mm tyres and rigid forks are tip toeing around every bump.
Re: 650b: hype?
Postby dubudu » Thu Nov 29, 2018 10:09 pm
Re: 650b: hype?
Postby RobertL » Tue Dec 18, 2018 11:00 am
I have an early 90's Shogun Trailbreaker frame and fork gathering dust. It's a biggish size - but I'm not sure what exactly (without looking closely).dubudu wrote:Thanks for the review Scott. Sounds wonderful. I was think of using them for foresty riding. You don't happening to have any old steel rigid mtn bike frames you feel like selling? Been looking around on gumtree, not much in Qld that I have seen. Steel, rigid fork and stays, canti. I don't have any experience with old mountain bikes, I guess clearance at the chainstays is the main issue.
You can have it if you want. Frankly, you'd be doing me a favour taking it off my hands.
Return to “Audax / Randonneuring”
- All times are UTC+11:00
