Spotted a special - Post it in here!
defy1
Re: Spotted a special - Post it in here!
Postby defy1 » Tue Sep 20, 2016 9:26 pm
still using the bike stand from the last sale. Good value. Does the job.
outnabike
Postby outnabike » Tue Sep 20, 2016 9:32 pm
I was in Anaconda at Narre Warren yesterday.
A bin full of helmets at under 12 each. I have heard of chaps buying cheap helmets to collect the Aus stickers.....don't know why.
Ross
Postby Ross » Sat Sep 24, 2016 4:20 pm
I just bought the Aldi front light (https://www.aldi.com.au/en/special-buys ... ure-light/) but the mount that is screwed to the light body came away while trying to attach the light to the handlebars so it is going back for exchange.
I mucked about for about 10 mins or so trying to screw the mount back to the light but the screws are so crappy I gave up. Shouldn't have to anyway on a brand new light (I know they are only $40 but they should be better made IMO)
Ross
Postby Ross » Sun Sep 25, 2016 7:50 pm
Exchanged the light no worries and mounted it on the handlebars ok this time. They didn't even look at the receipt, it could of been for a packet of WeetBix bought from an Aldi 300km away, 2 years ago! Battery is currently on charge (instructions say charge for at least 10 hours before using).
Sometime in the not too distant future I hope to try to do a beam shot comparison between this light and AYUPs.
I was happy that there is only a relatively short cable on the actual light and also the battery and not a 2m+ intergrated cable like a cheap Magicshine lookalike I previously had. This means I can mount the battery under the stem . There is a longish (~1m) extension cable supplied if you want the battery in your jersey pocket or elsewhere on the bike. There is also a helmet mount supplied for the light.
Postby Mulger bill » Sun Sep 25, 2016 7:59 pm
Ross wrote:I just bought the Aldi front light (https://www.aldi.com.au/en/special-buys ... ure-light/) but the mount that is screwed to the light body came away while trying to attach the light to the handlebars so it is going back for exchange.
Loose bracket on mine pulled up OK with a precision driver, thanks for the heads up. :)
The bracket itself is sized for standard bar diameter, if you're oversized it might pay to chop an old tube up to pack it a little.
Light is serious bright compared to my G1 AYUPs in a totally non scientific, prop them on the bars near the AYUPs and look at the shed wall twice test.
Methinks I won't be using the flash mode unless I'm planning on inducing seizures or starting a mobile disco.
Trevtassie
Postby Trevtassie » Thu Sep 29, 2016 3:08 pm
17.5% off at Velogear.... even on discounted items, the usual free post as well.
redsonic
Postby redsonic » Thu Sep 29, 2016 6:47 pm
Trevtassie wrote:17.5% off at Velogear.... even on discounted items, the usual free post as well.
Is there a code to quote for that?
Trevtassie
Postby Trevtassie » Thu Sep 29, 2016 7:47 pm
SPRINGSALE
Ross
Postby Ross » Fri Sep 30, 2016 6:32 am
The second set I got seemed to be ok, mounted them to the bike without any problems. I noticed the screws were covered on this one where they were visable on the first set and also another set I looked at in Aldi last night.
Plenty of pumps and tool kits still available, a couple of camelbaks, no repair stands left, and only one lightset.
Six13
Postby Six13 » Fri Sep 30, 2016 10:40 am
Merlin have 10% off most lights. Just picked up the very well regarded Cateye 800 for about AUD120 delivered
https://www.merlincycles.com/cateye-vol ... 86201.html
petal665
Postby petal665 » Fri Sep 30, 2016 10:53 am
They also have DA9100 in stock. Not really bargain pricing though.
Rex
Postby Rex » Fri Sep 30, 2016 11:33 am
petal665 wrote:They also have DA9100 in stock. Not really bargain pricing though.
Indeed not. Mechanical too :shock:
petal665
Postby petal665 » Fri Sep 30, 2016 11:41 am
Di2 is delayed a little bit.
davehirst
Re: Aldi bike work stand
Postby davehirst » Sun Oct 02, 2016 3:29 pm
Still got bike stands at Aldi Hornsby
Mububban
Postby Mububban » Tue Oct 04, 2016 12:15 pm
Anaconda have 50% off their Fluid range of adult bikes.
petal665
Postby petal665 » Fri Oct 07, 2016 1:28 pm
PBK has 9000 C24 clinchers down to $820 shipped using TREAT10
http://www.probikekit.com.au/bicycle-wh ... n=10781804
redsonic
Postby redsonic » Fri Oct 07, 2016 1:37 pm
Lots of bike stands, floor pumps, helmets etc still at Aldi Woody Point (Redcliffe, QLD)
caneye
Postby caneye » Mon Oct 10, 2016 10:43 am
Torpedo7 having a CASTELLI sale. gabba2 for only $150+, among other things ..
tron07
Postby tron07 » Mon Oct 10, 2016 12:31 pm
This Saturday, Aldi got a Torque Wrench, $29.99. Is the range good enough?
12.7mm (½") torque wrench with automatic quick release
Includes 17, 19 and 21mm sockets and 125mm extension bar
Heavy duty case for safe storage
Working range: 28-210Nm (measuring tolerance)
https://www.aldi.com.au/en/special-buys ... ue-wrench/
petal665
Postby petal665 » Mon Oct 10, 2016 12:33 pm
Bit high for most bike related uses.
Postby jasonc » Mon Oct 10, 2016 1:23 pm
petal665 wrote:Bit high for most bike related uses.
cassettes need 40Nm
garmin vectors need 38Nm from memory but that's a special use case
petal665
Postby petal665 » Mon Oct 10, 2016 1:40 pm
See how I said 'most'.
Postby jasonc » Mon Oct 10, 2016 1:43 pm
petal665 wrote:See how I said 'most'.
I missed the "most", my apologies
battler2
Postby battler2 » Mon Oct 10, 2016 2:40 pm
caneye wrote:Torpedo7 having a CASTELLI sale. gabba2 for only $150+, among other things ..
not really. fluoro yellow in small which is great for garden gnomes but useless for everyone else (srry i just watched trump debate, im good with insults right now). everything else is nearing 200 which is not much of a sale price.
great jerseys btw, only have them in SS but use arm warmers with them. higher range of temps than most winter jerseys with or without a baselayer (without can go up to near 20degrees).
rodneycc
Postby rodneycc » Mon Oct 10, 2016 6:00 pm
tron07 wrote:This Saturday, Aldi got a Torque Wrench, $29.99. Is the range good enough?
I reckon that's an auto (car) one. You are better off grabbing a bike specific one like an IronArm from Cycling express or similar (Bike Hand is the one I have that's exactly the same as that) for the same price. Maybe do a search for Torque wrenches as it had a thread on this recently.
Users browsing this forum: OnTrackZeD
