Postby Mr Purple » Fri Jan 17, 2025 12:18 pm
No idea why, batteries are fully charged and 'down' works fine. Strangely the 'holding the down shifter for multiple shifts down' function seems to work, but erratically and not under load. Everything's fully charged, haven't changed any settings.
It'll be interesting to see what it turns out to be. This is the advantage on having a relatively new Giant, I suppose - it's the shop's problem now.
Postby jasonc » Fri Jan 17, 2025 12:48 pm
this is one of the reasons I'm thinking about wiring my aethos - removing 2 batteries from the picture
Postby Mr Purple » Fri Jan 17, 2025 1:41 pm
Both fully charged, allegedly, according to the Shimano app.
Though it has the feel of a failing battery somewhere. In that it didn't break suddenly - it slowly got worse and worse until it stopped working completely. I've stuck the RD on charge but the bike's due for a going over anyway so I'll still drop it off at Giant this afternoon.
It might be something stupid like the switch in the shifter failing. It is a bit weird that 'down' was absolutely ok. In reflection I should have probably changed the shifting mode to see if double tapping worked.
Postby warthog1 » Fri Jan 17, 2025 2:59 pm
- Tim
Postby Tim » Fri Jan 17, 2025 3:22 pm
Been there.warthog1 wrote: Can't get the cable out the hole in the frame near the derailleur.
Pull the cable out. Tie a length of cotton securely to the end of the cable.
Feed the cable back in at the bottom bracket opening (I presume).
Suck the cotton out the end of the frame with a vacuum cleaner and gently pull/guide the cable through the hole.
Postby Mr Purple » Fri Jan 17, 2025 4:06 pm
Realised when I got home that the little mechanical 'click' that even Di2 has when shifting gears wasn't there on that lever.
Dropped it off at Giant who instantly confirmed the shifter is toast and will be replaced under warranty. Once again out came the phrase I hear a lot at bike shops 'I've never seen one break like that before'.
Postby warthog1 » Fri Jan 17, 2025 5:41 pm
I am pretty sure it feeds through plastic tubing inside the frame.Tim wrote: ↑Fri Jan 17, 2025 3:22 pmBeen there.warthog1 wrote: Can't get the cable out the hole in the frame near the derailleur.
May give that a go or a small magnet on a wire. Thanks
Postby jasonc » Fri Jan 17, 2025 7:02 pm
Wonder if they tried a shifter reset - installing the battery backwards for a few minutes, then reinstall correctly. Of course a pce2 would be the best way to confirmMr Purple wrote: ↑Fri Jan 17, 2025 4:06 pmRealised when I got home that the little mechanical 'click' that even Di2 has when shifting gears wasn't there on that lever.
- biker jk
Postby biker jk » Fri Jan 17, 2025 8:25 pm
Just use a good magnet to guide the gear cable through the opening. That's what I did.warthog1 wrote: ↑Fri Jan 17, 2025 5:41 pmI am pretty sure it feeds through plastic tubing inside the frame.Tim wrote: ↑Fri Jan 17, 2025 3:22 pmBeen there.warthog1 wrote: Can't get the cable out the hole in the frame near the derailleur.
Postby warthog1 » Fri Jan 17, 2025 8:26 pm
Thanksbiker jk wrote: ↑Fri Jan 17, 2025 8:25 pmJust use a good magnet to guide the gear cable through the opening. That's what I did.warthog1 wrote: ↑Fri Jan 17, 2025 5:41 pmI am pretty sure it feeds through plastic tubing inside the frame.Tim wrote: ↑Fri Jan 17, 2025 3:22 pm
Been there.
Postby blizzard » Fri Jan 17, 2025 8:36 pm
Mr P, I'm not sure how one person can be so unlucky with bikes, hopefully you have better luck with your cars.
Postby warthog1 » Fri Jan 17, 2025 9:09 pm
Postby Mr Purple » Sat Jan 18, 2025 12:18 pm
My initial thought was something to do with software or setup, but when I realised the lever completely lost its 'click' it's obviously mechanical. I'd say the switch just broke somewhere internally, so there'll be no fixing it with a software fix.
Blizzard - weirdly with my cars I'm the complete opposite! I've driven many absolute heaps over the years and none of my cars have ever let me down. Except for a 12-24 month period with my Mini when I broke absolutely everything on it, probably more to do with tripling the power output than anything else. Even that's reliable now (touch wood).
Postby warthog1 » Mon Jan 20, 2025 6:45 pm
Bingo! A strong magnet was what I went and got. Wasted time looking for one on a telescopic probe to go through the cable hole in the frame. Couldn't find one. Asked at Bunnings and the bloke showed me a wall stud finder magnet. Pretty bloody strong. Put that on the outside aspect of the chain stay near the hole. Out it came.biker jk wrote: ↑Fri Jan 17, 2025 8:25 pmJust use a good magnet to guide the gear cable through the opening. That's what I did.warthog1 wrote: ↑Fri Jan 17, 2025 5:41 pmI am pretty sure it feeds through plastic tubing inside the frame.Tim wrote: ↑Fri Jan 17, 2025 3:22 pm
Been there.
Postby jasonc » Mon Jan 20, 2025 6:52 pm
Postby warthog1 » Mon Jan 20, 2025 6:55 pm
You lucky man!
I was contemplating 12 sp di2 upgrade but price soon scratched that idea
Postby jasonc » Mon Jan 20, 2025 9:15 pm
Having something to run cables is still handy. You still have to run di2 cables with 12 speed
Postby warthog1 » Mon Jan 20, 2025 11:00 pm
Only have one di2 bike and it came built up. I like it though. Shifting is much better.
One day 12s shifters and derailleur may be affordable to upgrade the gravello.
Just bought a camper trailer and money is marching out the door on that and the 4wd at the moment.
Postby jasonc » Tue Jan 21, 2025 8:28 am
- MichaelB
Postby jasonc » Tue Jan 21, 2025 8:46 am
i bought an r8070 groupset, then bought grx di2 derailleurs. the groupset came with a power meter crank so i sold that to recoup some costs.
Postby warthog1 » Tue Jan 21, 2025 8:50 am
Just stupid $$ at the moment.
- MichaelB
Postby Mr Purple » Tue Jan 21, 2025 2:53 pm
Even after my brief Di2 experience with one broken shifter already I'm never getting a new mechanical groupset again. Unfortunately gravel bikes with Di2 groupsets are all ridiculously expensive!
Postby jasonc » Tue Jan 21, 2025 3:33 pm
I wanted one with Di2, but worked out it would be cheaper to upgrade the wheels and groupset than buy what I wanted. Not much standard left on my bike - frame, fork, seat post and stem is all that's left (and am about to replace the bars with ones that are di2 bar end capable)
- All times are UTC+11:00
