New Fly6 CE and Fly12 CE Camera's
- Retrobyte
Re: New Fly6 CE and Fly12 CE Camera's
Postby Retrobyte » Sun Nov 28, 2021 7:29 pm
- trailgumby
Postby trailgumby » Sun Nov 28, 2021 8:35 pm
I've found mine to be very good, but clearly there are some variations in manufacturing quality.
- Comedian
Postby Comedian » Mon Nov 29, 2021 8:03 am
That's probably OK in summer but it's going to be a big problem next winter. The Fly6ce which is at least two years old has more battery lift by a good margin.
- queequeg
Postby queequeg » Mon Nov 29, 2021 10:39 am
this was also a major reason i swapped to the Varia. It lasts 10+ hours with the light running in High Visibility mode. My Fly6 would last barely 4 hours in high vis flash mode, so i’d only have coverage for half my ride. turning the light off would squeeze another 90min out of it at best.Comedian wrote: ↑Mon Nov 29, 2021 8:03 amSo, the other thing about the Fly6 Gen3 is that I only get about 4 hours runtime without the light. Camera only.
- Comedian
Postby Comedian » Mon Nov 29, 2021 11:04 am
Looks like they need external power.. which is painful and impossible in the wet.queequeg wrote: ↑Mon Nov 29, 2021 10:39 amthis was also a major reason i swapped to the Varia. It lasts 10+ hours with the light running in High Visibility mode. My Fly6 would last barely 4 hours in high vis flash mode, so i’d only have coverage for half my ride. turning the light off would squeeze another 90min out of it at best.Comedian wrote: ↑Mon Nov 29, 2021 8:03 amSo, the other thing about the Fly6 Gen3 is that I only get about 4 hours runtime without the light. Camera only.
- trailgumby
Postby trailgumby » Mon Jan 10, 2022 12:26 am
The fact I had it off the bike and sitting on its back may have contributed to the electronics failure, but still a clear fault with the waterproofing of the case. Will post a photo when I can find a hosting site.
Postby jasonc » Mon Jan 10, 2022 8:17 am
postimg.cc is the current one i use
- Comedian
Postby Comedian » Tue Jan 11, 2022 8:37 am
Don't be hard on yourself. Water ingestion seems to be the #1 big problem for these units. I had mine take on a heap of water. I knew it was raining and double checked the rubber cover. I looked when I got home and I don't think it got in through the cover... the only other place is the speaker. I taped over that.. haven't ridden in the rain since.trailgumby wrote: ↑Mon Jan 10, 2022 12:26 amMy Fly6 carked it today. A couple of hours after a wet ride. Looks like the rear-facing bezel wasn't glued properly to the case and has let water in. Just submitted a warranty claim.
Early on cycliq support were being pretty difficult about this but a friend had hers replaced no qualms recently. It appears this only affects people who have ever ridden in the rain with their fly6.
- trailgumby
Postby trailgumby » Sat Apr 02, 2022 6:03 pm
Requirements:
- *reliably* waterproof without needing to use water housings
- better than 4 hours runtime, preferably 6+
- good number plate capture
- decent low light performance
- auto-overwrite of old files (ie, like a dash cam)
- user-replaceable battery
- GoPro style mount
- Able to be used rear-facing from say the saddle as well as from the bars
- integrated lights nice but not essential
Postby Andy01 » Sat Apr 02, 2022 7:35 pm
DJI Osmo Action (original, not Mk 2) - I use this up front
Up to 4K. I use 2.7K/60 and number plates are easily readable.
I haven't tried it much in low light, but it looks fairly decent (as action cameras go)
User changeable batteries
Waterproof to 10m without a housing
The included frame has a GoPro style mount
You could mount it anywhere you want with the appropriate mounts
Probably around 80-90 minutes at 2.7K/60 with stabilisation on on a battery. There is a port on the side (behind a removable door) that you could plug in a USB C power source, but I don't know how this would affect the waterproof-ness ?
It does have a "Loop" feature, but strangely it doesn't actually overwrite older files. I manually delete the oldest ride after each ride when I change the battery.
No integrated lights.
Mobius Maxi - I use this at the rear.
Theoretically it does 2.7K but I find that 1080P/60 is about the best. Number plates are mostly readable, but it depends a bit on the lighting.
I think it will do around 2.5 hours on an internal battery. The battery is user replaceable apparently (perhaps with some basic skills). You can easily connect it to a powerbank so it could run all day on a moderate powerbank.
It is actually quite popular as a dashcam so it loops seamlessly.
It comes with a little tray that it slides into. The tray has a standard tripod style screw hole, so it is fairly easy to attach to to a GoPro style arm if you get the intermediate screw mount. I have mine mounted up under my saddle - nicely out of the way.
Apparently low light performance is acceptable, but I haven't tried. There is lots of reviews online of this (for dashcam use).
Not at all waterproof, and I don't think there is a housing available. It is something I am aware of but not a big deal to me as I am a fair-weather rider.
No integrated lights. It is far too tiny (a little bigger than a standard matchbox)to have integrated anything.
They do the job for me, but my rides are typically less than an hour and in dry weather during daytime.
When I was searching I can't remember finding anything (perhaps anything available in Oz and "reasonably" priced) that had the features you want - except the FLY cameras and I wasn't going to touch them after reading the large number of poor reviews about very poor reliability and poor customer support.
Postby Cyclophiliac » Sat Apr 02, 2022 10:45 pm
- queequeg
Postby queequeg » Sun Apr 03, 2022 12:13 am
I am seeing a lot of Varia radar taillights out on the road these days. Mine is going strong. Lasts an entire 200km+ ride with the light going. It gives what the the Fly6 can’t…warning of danger. No reliability issues either.Cyclophiliac wrote: ↑Sat Apr 02, 2022 10:45 pmYes, I certainly don't plan to ever buy one of the Fly cameras. After following this thread (and the previous Fly cameras thread) since its inception, I'm not exactly impressed with their reliability.
Postby warthog1 » Sun Apr 03, 2022 2:51 am
Very happy with mine too.
- Comedian
Postby Comedian » Mon Apr 04, 2022 12:21 pm
I've just been given a warranty fly6 replacement for my last one which was 8 months old when it was drowned by one wet ride.
Anyway.. I just thought I'd mention that the new one appears to certainly have far higher image quality than the old new one. Looks like they have done running improvements.
The smaller size fits well with the varia. Will have to see how the battery goes.
Postby caneye » Mon Apr 04, 2022 12:35 pm
have also seen many riders using the Varia. feels safer when there's one in each bunch ride (you don't need more than 1)
Postby fenn_paddler » Tue Apr 05, 2022 1:53 pm
I wrap my Fly 6 CE in a sandwich bag secured with a rubber band whenever there's a sniff of rain (and it's lasted well as a result).
I replaced my Fly 12 with a GoPro Hero4 Session, but deteriorating battery life forced a replacement. Cycliq wasn't considered for many of the reasons outlined in this thread, so I'm trying the Ghost XL on the front. I don't think it is necessarily great on numberplates or in low light, but it is waterproof, has up to nine hours runtime, auto-overwrites files, and has a gopro style mount.
Postby Andy01 » Tue Apr 05, 2022 6:20 pm
I looked at those and they are not a bad option, but the video quality didn't seem to be the best 1080P out there and obviously only 1080P, which as per the Mobius Maxi, is marginal for number plates.fenn_paddler wrote: ↑Tue Apr 05, 2022 1:53 pmIs there any love for the Drift Ghost XL as a Cycliq replacement?
Postby Cyclophiliac » Tue Apr 05, 2022 6:26 pm
The problem is: once we get past 1080p, battery life tends to go down, and may not last for the entire commute/trip.Andy01 wrote: ↑Tue Apr 05, 2022 6:20 pmI looked at those and they are not a bad option, but the video quality didn't seem to be the best 1080P out there and obviously only 1080P, which as per the Mobius Maxi, is marginal for number plates.fenn_paddler wrote: ↑Tue Apr 05, 2022 1:53 pmIs there any love for the Drift Ghost XL as a Cycliq replacement?
- trailgumby
Postby trailgumby » Tue Apr 05, 2022 8:44 pm
https://www.tooocycling.store/products/ ... 2086235371
- Comedian
Postby Comedian » Wed Apr 06, 2022 8:30 am
Watching with great interest!trailgumby wrote: ↑Tue Apr 05, 2022 8:44 pmI've just received notification that my order for one of these has just shipped. Supposed to be more thoroughly waterproof, long runtime and better low light performance that the Fly6. Competition for Cycliq has arrived.
Postby Andy01 » Wed Apr 06, 2022 9:45 am
I have found this with my Arlo Pro 1080P security cameras - they are still technically 1080P but Arlo has pushed through firmware updates that has increased the video compression (to save them on server space I presume) to a point where it is sometimes hard to recognise a person that you already know never mind read a number plate. My Arlo 1080P video (for reference) would now give me 31,000 minutes of 1080P on a 128Gb card and I can tell you that it is pretty useless - blurry and pixelated - I have never tried it with a number plate but I would be astonished if you could read a number on a stationery vehicle at 10m with it, nevermind a vehicle doing 60km/h past a "bumpy" bicycle doing 30-40km/h.
Also, 105° lens is probably adequate but not very wide compared to most other dashcams or actions cams (which are 130-170°). I have no idea what the Fly6 is.
I didn't see any mention of image stabilisation, which though not "required" does improve the video quality and ability to read number plates. I reckon that the DJI Rocksteady is the primary difference in video "quality" between my Osmo Action and Mobius Maxi when both are set to 1080P/60, with the Osmo being quite noticeably clearer for number plates.
Likewise, 80 lumens light (assuming it is not over-stated like the recording time) is marginally adequate for night use, but probably not too good for daytime use. My Giant Recon TL 200 is OK but not blinding at 200 lumens. I think it may be a stretch to say that you would visible at 1.6km away.
I will be very interested to see how this performs against the stated specs and what the video quality is like.
- AUbicycles
- Site Admin
Postby AUbicycles » Fri Apr 08, 2022 5:58 am
But seriously, cycliq made a good splash and even though they became very quiet, I would have expected a lot more genuine competitors to have jumped in. Car Dascams are big business and automation, convenience and affordability in bike versions can really push for more interest among riders.
Will have a look too… keep me posted!
- Comedian
Postby Comedian » Fri Apr 08, 2022 4:41 pm
Cycliq really did a good job of hitting a market niche. A unique product that meets a need. One that is big enough - but no so big that lots of competitors pile into. A premium price, but one many are prepared to pay for a unique product.AUbicycles wrote: ↑Fri Apr 08, 2022 5:58 amIt points up…..
I think everyone genuinely wishes them well too.. an Australian company and all. They just seem to have been dogged by quality issues. Either what they are doing is really hard, or their suppliers aren't doing a good enough job. Maybe they need to switch manufacturers or switch country of supply. People I know in electronics manufacturing were bemoaning how their Chinese product started out being what they wanted, but unless someone was living there and watching over the factory quality would decline.
Personally I would happily pay $50 more if my fly6 lasted a long time.
- trailgumby
Postby trailgumby » Fri Apr 08, 2022 10:37 pm
Scheduled to arrive the day after Easter. Will keep you posted.
- foo on patrol
Postby foo on patrol » Sat Apr 09, 2022 6:51 am
Foo
Goal 6000km
